Grease issue
Old Sep 17, 2012 | 08:38 PM
Darknight84's Avatar
Grease issue
I'm working on getting things together for my sas trying to find out what grease i need for everything. Can i use multi purpose grease or do i need grease for one thing and another for something else I work for a parts Warehouse and we sell CRC stuff like that not sure what i need.
thanks
Old Sep 21, 2012 | 09:57 AM
OrRunner's Avatar
Use OEM suggested grease.
Old Sep 21, 2012 | 08:56 PM
4Crawler's Avatar
I usually use a good moly fortified grease (compatible with the one listed by Toyota) and use that on most everything, tube in a grease gun. Only thing I grease different is the birfields, I'll use something like CV joint grease in those, since they are CV joints. I usually have a small 1 lb. tub of CRC synthetic wheel bearing grease that I use for greasing those small parts, like knuckle bearings.
I think Toyota lists 2 general grades of grease, a lower end lithium grease for slow moving/low load parts and a higher end moly grease for fast moving / higher load parts. I just use the better grease in almost everything.
Old Sep 22, 2012 | 08:02 PM
Ok cool thanks
Old Jan 6, 2013 | 08:22 PM
so i should be ok using general purpose the peanut butter color stuff
crammit442
7
Nov 29, 2017 12:30 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RBK
Aug 1, 2015 01:55 PM
calderp
Jul 27, 2015 09:58 AM
PlayAwhile
Jul 20, 2015 11:36 AM
