Grease issue
Grease issue
I'm working on getting things together for my sas trying to find out what grease i need for everything. Can i use multi purpose grease or do i need grease for one thing and another for something else I work for a parts Warehouse and we sell CRC stuff like that not sure what i need.
thanks
thanks
I usually use a good moly fortified grease (compatible with the one listed by Toyota) and use that on most everything, tube in a grease gun. Only thing I grease different is the birfields, I'll use something like CV joint grease in those, since they are CV joints. I usually have a small 1 lb. tub of CRC synthetic wheel bearing grease that I use for greasing those small parts, like knuckle bearings.
I think Toyota lists 2 general grades of grease, a lower end lithium grease for slow moving/low load parts and a higher end moly grease for fast moving / higher load parts. I just use the better grease in almost everything.
crammit442
7
Nov 29, 2017 12:30 PM
