Clearancing SFA for High Pinion 3rd member
Old Jun 19, 2009 | 08:24 PM
swapped89's Avatar
So i know i need to clearance my axle housing to fit my new high pinion third into it. I just wanna read someones elses write up before i go grinding away. Yes i searched everywhere marlin site TG site here google ZUK just cant find pics or anything on someones axle housing clearance job.
Old Jun 19, 2009 | 08:39 PM
4Crawler's Avatar
No problem putting one in my '85 front axle. At the most you may need to slightly enlarge (grind) the top and bottom notches in the housing to allow the gear teeth to fit through. Some gear ratios and brands have slightly taller teeth and need a little extra room.
Old Jun 19, 2009 | 09:00 PM
swapped89's Avatar
it needs to be ground down also around the bearing caps. they hit before they are even half way in. the gears are huge compared to the notches in the housing. They are 529 yukons and it has an ARB.
Old Jun 19, 2009 | 09:50 PM
4Crawler's Avatar
Mine is factory 4.88 gears and an ARB. I had already ground out the notches for the 5.29 gears I originally ran in a low pinion 3rd.
Old Jun 19, 2009 | 10:53 PM
swapped89's Avatar
i see. the way TG routed the copper line i had to clearance for it also. it was a pita grinding and checking and grinding and checking... etc....these 3rds are heavy, and those lines are fragile. Nevr the less. i m pretty sure its ready. im gonna wait for mornig to install it cause i really wanna be careful so i dont pinch the copper line.
Old Jun 20, 2009 | 08:11 AM
4Crawler's Avatar
Ah, I had Marlin set up my ARB and when I first saw the way the copper line was run, I wondered why it was bent in all those strange ways. But when I went to install the 3rd, that is when it made sense. It fit in like a glove, not a single issue.
Old Jun 20, 2009 | 11:26 AM
swapped89's Avatar
well if i ever get one for the rear i'll spend the extra 100$ and order it from marlin instead of TG. the routing on the copper is ridiculous beyond close to the axle housing, it touches everywhere!
Old Jun 23, 2009 | 01:57 PM
swapped89's Avatar
could'nt find what i was lookin for so i just went at it by myself. here are some pics
I had to grind the housing on the sides to clearance for the large bearing caps on both sides. not too much but a good 1/8th inch or so. Also had to widen the ring gear channel about 1/2 to 3/4inch wider. And a lil grinding on the top right where the copper air tube was routed around the bearing caps.
You can see where the housing is not round anymore between the 3 studs. this is so the bearing caps would fit.
ring gear channel you have to do the same on top and bottom
Lil bit of grinding for the copper line/ between the two studs
Finally after grinding and checking over and over i got it ti fit just right.
Old Jun 23, 2009 | 09:25 PM
BLKNBLU's Avatar
I had the same problem with mine (reg diff not HP) and ended up tweaking the copper line. I didn't have to grind mine anywhere near what you did, just at the notches for the ring gear. Discussion here at post #155:
https://www.yotatech.com/forums/f66/...72/index7.html
When ZUK and I looked it over we spent a lot of time test fitting it into a housing he had on premesis. He also mentioned that he thought the copper routing was new since the new bearing seal design from ARB. In the end I was just probably careless when I installed the diff in the first place as I didn't have to grind any additional material off the housing to get it in.
Old Jun 23, 2009 | 09:46 PM
neoworm0's Avatar
Hmmmm, hi-pin with yukon 4.88's and an ARB. 1981 housing. No grinding. Just went right in?
Old Jun 23, 2009 | 10:39 PM
swapped89's Avatar
thats probably because yours was not a High Pinion. the High Pinion diffs are from landcruisers hence they are a lil different than the runners and trucks, 3rd members.
Old Jun 24, 2009 | 07:19 AM
4Crawler's Avatar
My ARB is the older design (installed around 2000 or so), so maybe that explains the lack of problems installing it.
Old Jun 24, 2009 | 01:47 PM
neoworm0's Avatar
I have the newer design ARB in mine and it still went in without modifying the housing. It was tight but a bit of patience and in it went.
Old Jun 24, 2009 | 01:53 PM
swapped89's Avatar
Is it hi-pinion though? thats what im talkin about
Old Jun 24, 2009 | 03:30 PM
neoworm0's Avatar
Here, I highlighted it for you this timeOUt of a 93 FJ.
Old Jun 30, 2009 | 01:40 PM
Blizzard's Avatar
At first I run a 4.88 OEM HP Diff from a 70 Series Land Cruiser on my front axle. Didn't have to clearance anything. It's exactly the same than the ones found on open diff 80 Series LC.
Now I've a fron HP E-Locker with the same 4.88 gears and only had to clearance the locker fork zone like on the rear when retrofitting a regular E-Locker and change a bolt of the locker motor.
Will see what happens when I put 5.29's (Made the auto conversion later).
David
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
kirkrunner
Jul 27, 2015 07:59 PM
