can i do it sas swap ??
Old Apr 14, 2009 | 01:53 AM
philmoon's Avatar
Hi guys have been contemplating sas for a while now but I have just broke the car so figure now is as good a time as any
so I have read lots and lots about this but just got two or three little Q's
ok so I have a 3vze auto on 92 plate is there anyting special that would stop me doin it (like transfer case on wrong side or ???)
will I need different tail shaft or get the one I have machined down / up ?
Old Apr 14, 2009 | 08:28 AM
4Crawler's Avatar
Might help to tell us what sort of vehicle you are talking about.
Old Apr 15, 2009 | 12:34 AM
philmoon's Avatar
its a 92 plate 3lv6 (3vze) hilux 4 runner with IFS on it
Old Apr 15, 2009 | 05:39 AM
waskillywabbit's Avatar
Find some SAS write-ups on your vehicle or one close and read. Tons of info on SASs and lifting the rear.
You will need driveshaft work afterwards.
Old Apr 21, 2009 | 09:02 AM
whokrz's Avatar
Do you have a welder?
Old Apr 21, 2009 | 09:59 AM
algranger's Avatar
Yota axles have a passenger side drop
Old Apr 22, 2009 | 11:11 PM
philmoon's Avatar
no welder but a pal of mine is a boiler maker ( welder / fabricator)
Old Apr 23, 2009 | 12:21 AM
dropzone's Avatar
Fossilized
read all you can before you order anything. tack before you fully weld. check shackle angle with wieght of truck on axle before you weld.
front hanger placement advice;
Front Spring Hanger Placement: (when using longer than stock springs like Trail Gears)
Originally Posted by ScottyC
He can't with the 3" springs. In fact, he needs to mount it 1/4" back of the front crossmember for a decent shackle angle and to have the tie rod and draglink clear each other on compression. Otherwise he'll be having to move the steering box forward.
I have all of these lifts down to a science at this point.
3" springs: 1/4" in back of the frame. Push the frame tube jig all the way forward in the body mount.
4" Springs 1/2" in front. Center the frame tube jib in the body mount
5" springs 3/4" in front. Center the frame tube jib in the body mount
Flying91
45
Apr 11, 2024 04:39 PM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
Backcountry411
Jul 24, 2015 08:06 AM
boogiewoogie
Jul 24, 2015 05:10 AM
