camanche axels
Old Jan 6, 2008 | 12:17 AM
808 yotaz's Avatar
camanche axels
jus was wondering if any one out there tried to swap toyota axels whit camanche axels or if heard such a thing? OR IS IT EVEN POSSIBLE!!!!!!!
Old Jan 6, 2008 | 07:14 AM
EWAYota's Avatar
if your referring to Jeep Comanche axles, not sure why you'd do that.
Old Jan 6, 2008 | 07:37 AM
dropzone's Avatar
Fossilized
Toyota SA's are on par with a Dana 44, stronger if you truss and do Longfield axles. The axles on a commanche were dana 30's or 35's if I remember correctly. Anything is possible for a good fabricator but you also need to look at differential locations etc etc...
Old Jan 6, 2008 | 02:30 PM
AppleJack's Avatar
Some Comanche's came with rear D44's, but with Toyota's 8in being about the same strength, as mentioned before, why would you do such a thing?
Old Jan 8, 2008 | 07:29 AM
TrikeKid's Avatar
And the front is a weaker D30. Also, you'd need a different transfer case, because the Comanche uses a drivers side drop front axle, where the Toyota is passenger side.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
Project90
Sep 24, 2015 11:40 PM
user 82300
Sep 15, 2015 05:49 AM
MudDr
Sep 12, 2015 01:47 AM
