92 lift springs.
Old Feb 12, 2013 | 08:06 PM
92Yota,SBC power's Avatar
92 lift springs.
I have a 92 pickup that im starting to plan.. i have my front axle for it now and would like to get idea what im gunna be running for suspension and steering. id like to have leaf springs front and rear and was thinking of using skys high steer kit and 30 splines, SBC etc. Sky makes a 9 inch front lift spring that i see but there is nothing to match them for the back. Is anybody running these springs, if so are they okay?? is there any company out there that makes springs bigger then 9 inch? or is there springs from ford, chev, dodge that i could fab up to work to get the hieght id like. Id like to be around 12-15 inches above stock. thanks.
Old Feb 12, 2013 | 08:29 PM
niall's Avatar
9" is HUGE on these trucks. I think you'll find most guys try to keep it as low as they can with the size tires they want to run.
What is your intended use for the truck?
Old Feb 12, 2013 | 08:33 PM
The truck will be used for offroad only, mostly trail riding and mud. not a street legal truck. planing on 38.5 to 39.5tsl tires.
Old Feb 12, 2013 | 10:53 PM
JonnyBoy's Avatar
Where are you that you need 12 to 15" of lift for trails? If it's going to be trailered, you don't have to worry about sheet metal as much, are you opposed to cutting some room for tire clearance?
I'll bet you didn't post here to hear people talk you out of a big lift, but I'm just making suggestions that some people may be able to run with a little easier. I would think that if anyone has ideas how to match the rear it would be Sky, so maybe give them a call?
1uzRunner
63
Nov 10, 2018 03:58 PM
punks_is_4x4
May 31, 2016 06:03 AM
_Nicco_
Sep 21, 2015 03:06 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
