87 4runner sas
Old Jun 27, 2008 | 08:51 PM
broskyo's Avatar
87 4runner sas
I'm starting my sas on my 87 4runner. Today I began cleaning up my 83 axle. I am going to be using the 3in trail gear kit with 4.88 locked front and rear both with lockrights. Still not a 100 percent sure on how I'm going to lift the rear. Will try to get some pictures of progress in the next few days.
Old Jun 27, 2008 | 09:27 PM
john rumbo's Avatar
goodluck on bid
Old Jun 27, 2008 | 09:28 PM
john rumbo's Avatar
sorry reply on your build to many beers
Old Jun 28, 2008 | 05:13 AM
waskillywabbit's Avatar
On a 4Runner typically go 1" higher in the rear, on a pickup go the same.
Not sure how you are going to lift the rear? Does that mean you are trying to decide between 3 link, 4 link and leaf springs?
Order from me and save the sales tax.
Old Jun 28, 2008 | 10:42 AM
broskyo's Avatar
I'm planning on doing the rear with leaf springs just not sure if I'm going to go with longer leafs or leave it stock length.
Just to save money I was thinking 3in downey leafs with an add a leaf and then a 1 1/2 shackle lift
Old Jun 29, 2008 | 05:57 PM
broskyo's Avatar
Started cleaning up the axle and taking the hubs apart, just need to get my 54mm socket.
Old Aug 21, 2008 | 12:33 PM
broskyo's Avatar
My camera isn't working so I cant show pics but the top half of the ball is pitted really and I don't know what to to do about it. Resurface?....or just leave it?
Old Aug 21, 2008 | 12:49 PM
broskyo's Avatar
got the camera to work
heres wat ive got done so far
Old Aug 22, 2008 | 12:33 PM
broskyo's Avatar
Bump!!
Old Aug 22, 2008 | 03:08 PM
88wildrunner's Avatar
i would just try sanding it, mine had a little bit of that so i just sanded it. make sure when you rebuild it to use plenty of grease to keep the ball and the birf lubed up.
good luck on the build.
Old Aug 23, 2008 | 06:08 AM
dirtoyboy's Avatar
I just use sand paper or a scotch brite pad
Old Aug 23, 2008 | 05:58 PM
broskyo's Avatar
OK well I've used some sandpaper and touched it up with a soft wire wheel and I think I got it about as good as I can. Now I'm just having problems getting the axle oil seal out.
Old Aug 23, 2008 | 06:05 PM
$5 seal puller
Old Aug 24, 2008 | 04:57 AM
dirtoyboy's Avatar
I usually use a giant flat head screwdriver.....jam it into the seal and pry it out....
You're putting a new one in anyways...good luck!
Old Aug 24, 2008 | 11:57 AM
broskyo's Avatar
I tried the screw driver thing for about 30min never got it to work so I will be buying the tool
Old Aug 24, 2008 | 12:13 PM
dirtoyboy's Avatar
You aint trying hard enough! hit the screw driver with a bfh until it goes in then pry it out...the seal will be mangled by the time u get it out
Old Aug 24, 2008 | 02:17 PM
broskyo's Avatar
Ya I tired harder and got them out so now I'm just waiting on getting the 3rd member gasket...So my friend who lives out on a farm that had the welder and torch I was using cant have anybody over any more because one of the kids out there pissed of his dad so now I'm on the search for a welder I can use it to put on the armor.
Old Aug 24, 2008 | 02:18 PM
Spinnbait's Avatar
Use a punch (or old screw driver) on one side of the seal and then another time 180 degrees away. Crinkle/fold the seal a bit by hitting these two points and then pull it out with pliers.
Old Aug 24, 2008 | 02:26 PM
Team420's Avatar
^ Good Tip ^
Old Sep 11, 2008 | 05:20 PM
broskyo's Avatar
I'm back in school so I have access to a parts washer and I got one side of the knuckles and hubs all cleaned next week I should be able to do the other side. This weekend I should finish welding the gusset and amor and get started on painting the axle
