01 4Runner - SAS - Is my steering too flat?
Old Mar 29, 2014 | 05:06 AM
LINY4Runner's Avatar
Finished up my 01 4Runner 3-link SAS a few months back and have been battling a death wobble ever since. I've been through absolutely everything;
  • Correct toe and caster
  • Check bushings on 3-link
  • Check geometry on 3-link
  • Raised axle-side mount on panhard bar to make it more parallel with drag link
  • Replaced rubber bushings in track bar with solid joints
  • Replaced tie rod ends
  • Rechecked torque on trunion bearings
  • Rechecked torque on wheel bearing
  • Balanced tires
  • etc...
Yes, I have had someone rock the steering wheel while I poke around for movement. Nothing is loose.
The fabricator who I'm working with mentioned that he thinks my steering may be TOO flat...can anyone confirm?
Attached Thumbnails 01 4Runner - SAS - Is my steering too flat?-dsc_0024.jpg
Old Apr 2, 2014 | 06:25 AM
Red Leader's Avatar
Man, beautiful runner, wish I could help.
Any closeups of your setup?
Old Apr 2, 2014 | 08:35 AM
RBX's Avatar
RBX
Wow, I thought I replied to this before.
No way to tell if it's too flat from a pic.
What is the caster set to?
What is your toe?
Have you adjusted the steering box adjuster screw?
Do you have a steering stabilizer?
Wheels balanced?
Get us more pics of the suspenion close ups of the knuckle steering and drag links.
crashburnoveride
Aug 28, 2015 09:20 PM
msane99
Jul 11, 2015 08:08 PM
Nickdigg
Jul 7, 2015 06:04 AM
karbin
Jul 5, 2015 11:37 PM
