Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
View Poll Results: Possible Dates for Whipper Snapper Meltdown?
August 18, 19, 20th
9
52.94%
August 21,22 & 23rd
0%
I don't care, just get me there, I need a rock fix
47.06%
Voters: 17. You may not vote on this poll
Whipper Snapper Summer Meltdown 4Runner Jam
Old Aug 21, 2006 | 05:28 AM
  #441
Stump1883's Avatar
It hasn't changed a whole lot, it's just a bit more washed out, but a little goes a long way on an obstacle like that.
Ryker, glad to see you made it home alright, even if it did take a little longer than anticipated. In all the ryush to get loaded up and get out, I forgot to tell you, PLEASE THANK TYLER for me, his grip tape idea saved me from adding to Murphy's Law. Your sliders were soaked and as I was climbing into your beast I slipped and almost took a fall into the tires and cut up fenders, the grip tape was there just in time to catch my left leg.
Old Aug 21, 2006 | 05:29 AM
  #442
neliconcept's Avatar
teaser pics
yeah hoes that is a geo getting up slick rock
Old Aug 21, 2006 | 05:46 AM
  #443
waskillywabbit's Avatar
Next Tellico trip...
Old Man's Show Them How It's Done Run
Whipper Snappers 0
Tellico 1
Old Aug 21, 2006 | 06:23 AM
  #444
bamachem's Avatar
Originally Posted by neliconcept
that buggy pulling Rob had to winch up it so yeah it was pretty damn hard.
2 other buggies made it.. the other three winched up.
yeah, but look at that "buggy". not exactly what i'd call hardcore with his near-bald 32 slicks on there. the lack of sheet metal may give him courage, but not necessarily the ability to wheel any better.
i just know that if i didn't have a busted CV and another weakened one that i would have given it a shot and i feel like i could have made it.
a front locker on that is the key. once the tires go up and over, then it's a matter of pulling the ass-end up to follow.
anyway, i'm glad you guys had a fun and safe trip. i wish i could have made it, but my plate is overflowing now at work. i doubt i'll make anything at all until this project is done about 11 months from now.
Old Aug 21, 2006 | 07:21 AM
  #445
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Well after hitching a ride with Scott and his dad in order to get back for classes, there is a killer loose on campus so campus was shut down and classes were cancelled...AAA also confirmed that no one had been sent out to pick up my car ....i'm just hoping there's enough time for the dealership to order and get parts to do the fix before this weekend
Old Aug 21, 2006 | 07:30 AM
  #446
bamachem's Avatar
ouch. did you pull the complete shaft axle out of the knuckle/hub assembly? i hope that you just cut out the center section of the axle out and left the outer (in the knuckle/hub) and inner joint (in the front diff) in place... if you pulled the whole CV out and didn't leave anything in, then you've killed your outer bearings in the knuckle, probably the hub & the knuckle itself, and possibly the ones in your front diff as well as contaminated the front diff lube by having it open to the environment.
Old Aug 21, 2006 | 07:37 AM
  #447
His CV is in place.. couldnt even break it loose to pull it out. We are afraid we did break his spindle too but not totally sure.. dude AAA better get their damn act together and get your truck out of there.. thats some bs
Old Aug 21, 2006 | 07:41 AM
  #448
nc994run's Avatar
We pulled out all of the front axle except the tri pod, because it was just stuck in there. The wheel bearings didnt come out until the bottom of 5 right before the water crossing. I'm not exactly sure as to what would have been exposed to the environment by having that in place...still learning about the front axle/ assembly
Old Aug 21, 2006 | 07:43 AM
  #449
nc994run's Avatar
also, i have a good video of myself getting winched up the final ledge... i am loading it to photobucket right now and will have a link to it shortly
Old Aug 21, 2006 | 07:48 AM
  #450
bamachem's Avatar
scott, you were there when i pulled my pass-side center section at the top of slickrock back in may, weren't you? why didn't you just take the swaybar endlink off, cut the boots, and then remove the center section of the axle shaft, leaving the inner and outer pieces in place?
you have to leave the inner "joint" in place to center the bearings on the front diff and keep it sealed from the environment. you have to leave the outer section in place in the knuckle/hub with the nut on it to keep the wheel bearings in place and to keep them from spinning out. with that said, to keep a broken CV from flopping around and causing more damage, you have to cut the inner and outer boots, slide the center axle towards the diff (with the front wheel turned away from the sway bar endlink, then slide the axle shaft out of the outer joint, then pull the center section completely out. that will keep the bearings in place and you can still drive in 2WD or 4WD (with the center diff locked), but if you don't have a front locker, then you're in 2WD anyway. you'd only need to put it in 4WD if you wanted the low gear of 4-LO.
Old Aug 21, 2006 | 07:56 AM
  #451
nc994run's Avatar
here's a link to the video of me going up ledge 3...and the best part is the last
http://s29.photobucket.com/albums/c2...t=DSCN0506.flv
Old Aug 21, 2006 | 08:01 AM
  #452
hokiefan2008's Avatar
So here is to my first post... i want to say thanks to all the guys that were down there this weekend for ALL their help... i have to say over all, looking back, i had a Blast. SO now i just need to sell my Chevy S-10 and get me that 1st Gen 4Runner i have always dreamed of. And here are some pics, ill post more later, once i make it back to school.
Old Aug 21, 2006 | 08:36 AM
  #453
nc994run's Avatar
My truck should be arriving at Toyota of Knoxville on Parkside drive around 2 15 this afternoon....then we'll see what the damage is
Old Aug 21, 2006 | 09:26 AM
  #454
justinh's Avatar
Y'all need to start carrying people's #'s that aren't there. I don't want to speak for anyone else in the Atlanta area (though there are others with trailers) but I am only about an hour south of Tellico and have a tow rig and trailer at my disposal as well as a knowledge of the area and a Toyota dealership 5 mins from my house. So, next time you go and run into trouble feel free to call me, if you want my number pm me. Maybe it is time to start a calling list of people with location and the resources they have available to them along with any special knowledge/skills they have.
  #455
1985 4Runner's Avatar
I'm glad they finally got yout truck picked up Rob! Keep us posted on the damage.
I finally got caught up on some sleep & am going to look at my damage later today.
So far I know I ripped the fender again, fan blade popped a hole in the radiator, which overheated the truck causeing a possible head gasket to blow.
Here's some more pics:
After Geg & I got the ATV back up on the road (this was when he got stung)
Old Aug 21, 2006 | 10:16 AM
  #456
nc994run's Avatar
A calling list would be good resource...I figured AAA would handle it better than they did....they called and got someone setup but the driver decided he didn't want to do it, so i notified AAA that he wasn't coming, and the person i had been talking to didn't do anything further to setup another driver.
Old Aug 21, 2006 | 10:29 AM
  #457
justinh's Avatar
Yeah, I hate dealing with AAA.
Old Aug 21, 2006 | 10:38 AM
  #458
hlpressley's Avatar
Scott
I really didn't contribute anything at all to the trip or to the recovery of any of these vehicles due to being a newbie myself however, I would like to give some big thanks to Scott.
This guy really ranks up there with me. I have only been around him twice and he spends every minute trying to help someone out! He spent pretty much all day Saturday helping everyone get their rigs fixed and or extracted while his sat parked at the base of slickrock. I personally have never seen anyone as young as Scott that is so concerned with the well being of everyone around him. He will do anything to make sure everyone has the best time possible. I hope that some day with a lot more experience and knowledge I too can give the effort that I have seen Scott give on the trails. He is truly an assett to our sport and eventhough I haven't broke anything for hime to fix (yet) LOL. I am truly thankful for people like Scott and couldn't think of a better person to be on the trail with. Thanks alot Scott! It is people like you that make this world a better place!
P.S. Give your Dad a big pat on the back also because I am sure you didn't learn to be so considerate and helpful by yourself. Tell him I may need some pointers as I have three little ones of my own to try to raise up the right way. :bigclap:
Old Aug 21, 2006 | 10:54 AM
  #459
More pics:
Old Aug 21, 2006 | 10:58 AM
  #460
Video:
Click here to watch Doc1-90
