Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
Where to find Southern UTAH Info?
Old May 4, 2007 | 11:08 PM
Elvota's Avatar
Originally Posted by SOAZtim
Sunday: Go down hole in the rock road/ smokey mountain (either or both if its worth it) Turn around at the dead end and go over on the Burr trail into capitol reef and then ...
Thats as far as I have planned so far.
I'd suggest looking into Collet Canyon Road. This will connect Hole in the Rock to the Smokey Mtn Byway. It will save you the long trek back into Escalante. You won't miss much on the first part of Smokey that Collet Canyon will bypass. Plus I am thinking Collet would be a very fun route.
I have not actually driven Collet Canyon. So don't let me get you in over your head. However, I have heard it is reasonable, but probably requires 4WD. The road actually heads up the canyon and then climbs to the mesa just W of Hole in the Rock Road. You can see the route on Google Earth. Also will show up on a good atlas. We will definitely be trying Collet next time we are in the area.
Always keep an eye on the weather upstream from you. We were going to try Collet Canyon this last trip but heavy clouds to the W made us think twice. Wouldn't want to be there when the rains get heavy. Same applies for exploring the slot canyons on foot... but I am sure you know all this already.
Also, even though Smokey Mtn Byway is not an advanced 4WD road, there are some sections that will require thought. High clearance would be strongly suggested. Stock 4Runner will be fine. Lot's of washes to cross as well. They were mostly dry for us, but I could see them getting very deep with weather. You'd be stuck with no way forward and possibly no way back if the level rises.
Be prepared to last for a few days on this road should something happen. There is limited (as in basically no) cell service and a very, very low volume of traffic. You are on your own and should be as self sufficient as possible. Unless you can communicate with cows... there seems to be a few of those out there. "Run for help Bessie... run like the wind..."
Try to work out a way you can let some one know your route so if you don't show up, they have a place to start looking. Escalante and Utah are way to big for a search party to just guess.
Not every truck problem can be fixed with a mere Peach can after all.
Old May 5, 2007 | 10:44 AM
XPLORx4's Avatar
SOAZtim- plug these coordinates into your GPS software, so you can figure out where to go:
Dry Fork Parking Lot: N37 28.589 W111 13.210
Peekaboo Gulch Start: N37 28.885 W111 13.000
Peekaboo Gulch End: N37 29.105 W111 13.005
Spooky Gulch Start (Top): N37 29.088 W111 12.565
Spooky Gulch End (Bottom): N37 28.890 W111 12.525
Old May 7, 2007 | 08:56 AM
SOAZtim's Avatar
Perfect! I'm going to save myself a lot of time and head ache during the trip, by putting in turns I need to make, stops, hikes, camping spots etc in my gps. That way I can always go somewhere else, but I'll have tons of things marked too. Thank you!
Old May 7, 2007 | 08:39 PM
SOAZtim's Avatar
xplorx4,
I just put thos coordinates in. Thankyou!!
Old May 30, 2007 | 03:31 PM
  #25
SOAZtim's Avatar
I just gotta say a BIG thank you! for all of the help. The trip was a blast.
Before:
and after:
With tons of stuff in between!
I've got a ton of pics to go through and post.
Thanks,
Old May 30, 2007 | 08:02 PM
  #26
Elvota's Avatar
Rig looks much, much better in the after.
Glad you had a good time. Utah is an amazing place.
the1998sr5
15
Jul 14, 2020 08:35 PM
shisha1999
Mar 16, 2016 12:25 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
88yodabasket
Jul 13, 2015 01:32 PM
