Co4rj 2005
#341
Originally Posted by Flygtenstein
I have PayPal from:
-Isaac
-Jim
-Schaefer
-John
-Jeff
-Ziad
-Mike B.
-Casey
-Brian K.
-Ric
Cash in camp works.
Erika, that was funny.
-Isaac
-Jim
-Schaefer
-John
-Jeff
-Ziad
-Mike B.
-Casey
-Brian K.
-Ric
Cash in camp works.
Chris
#342
Originally Posted by ravencr
So, sounds like you've changed things up a bit, Steve. Is your new setup 3 5/16 8" wheels with MTR's? It wasn't clear to me? Why'd you get rid of the Yoko's?
Chris
Chris
Off Road Set:
35x12.5x15 Goodyear MT/R on 15x8 MT Classic II
On-Road Set:
315/75/16 Yokohama Geolander AT II+ on 16x8 MT Classic II
Today I will put the On-Road set back on for the drive up there and at the campsite swap back to the MT/R's. With the power tank and an impact wrench, it will go fast.
#344
Brent's got wood, good call. Does this mean the rig is done?
I have the most pimpin wheels beeetches!!
#345
#347
That Bent Up Hydro line is pretty easy to put together, the big cup part you put in first, threads backwards and then you screw the nipple part in all the way. The blue adapter also is english threads that is "close" so use teflon tape.
I only used one of those at the box and I had Stubbs TIG weld on an AN end to the stock factory Banjo end so I retained the two vaccume lines on the 2.7, your motor might be different.
So basically I have an AN end on my pump right to the hydro line and then the 90 degree and the blue adapter into the FJ box.
FWIW ORS used those blue "close enough" on Cheeses steering as well. We found those out on Terminator that night.
#349
Well, I put the Yokos back on and boy does that thing look GAY !!!
I can not even believe I wheeled those street tires (Drag Slicks) through what I did. Having all the traction of 35" MT/R's is going to be unreal.
#353
Hunt, did I read that correctly on your site about your headlights being 5.5' high? That seems pretty high, but the more clearance the better, in my opinion. Someone may have already asked, but will we see it at CO4RJ?
Chris
Chris
#354
I talked with Joan at lunch. She reminded me again no dogs in the group site. I thought that was not what she told you John.
John
#359
Originally Posted by sschaefer3
Well, I put the Yokos back on and boy does that thing look GAY !!! I can not even believe I wheeled those street tires (Drag Slicks) through what I did.
