Looking at 2 4Runners
Hello guys, I am new here, but not new to forums. I first want to say I didnt see a member introduction area, but if I missed it please move this thread. Second, I know there is alot of knowledge to be found on a forum and thats what I am here for.
I am currently in talks of trading my harley sportster 1200 for one of 2 toyota 4 runners. I partly wanted to bounce them off yall and see what yall think.
I had a 87 toyota truck with the xtra cab area when I was in high school. It had the 22R and all I did was put on a 3" BL and 35" mud kings on steel wheels. Loved the truck but needed something to travel in for my first real job and sold it for a down payment on a 06 F150 2x4 extended cab. Regret selleing....... But now I have 2 offers on the table, this is where yall come in.
I have a 07 F150 that is my mall crawler, its just a purtty toy. I have a ford escort for my gas saver, around town car. Car cost me 700 bucks, runs like a top, cold ac, has heat power mirrors, only bad thing is that goofy tint.
look good truck, a gas saver car, I never ride the harley because I dont like riding alone. So the Toyota would be a work truck around the house and a play toy in the river bottoms.
Here are my two offers.
1st, I havent seen this one in person but it is a 88 4 runner
Here is what I know about it right now
It has a 4 cyl. 10" lift (IFS) 5.29 gears front/back on 37" co op tires, no carpet, 2 sets of front seats, hurculined around the bottom ( rockers) and PTM
Here it is:
option 2 is a 1987 4 runner, I have seen this one in person
Here are the detail's
chevy 5.3 v8 under the hood with a turbo 350 trans and manual valve body
all pro springs front/ rear ( has a straight axle already)
locked front/ rear ( welded spider gears) with 4.10 gears
high steer chomoly axle shafts in the rear
has a longfeild for the front, front axle has just beenrebuilt
38" swamper tsl
Full custom ( professionally) installed roll cage
custom front/ rear bumpers, 8000lb warn winch in front ( new)
Here it is
I am planning on it being a toy but not too rough on it! I cant decide which one I want. I think I want the one with the v8, it has the roll cage, sas, motor, winch, no body damage other than some rolled finders. everything looks good on it. I will rhino line the interior.
so what do yall think, any thing I should look out for or anything like that?
Here it is:
38" swamper tsl
Here it is
I think you'll be happier with the 2nd choice. Its got way more money/power put into it. if you're gonna get one to wheel, the 2nd choice would be the best. replace those welded spider gears with some lockers and all will be good.
I like the second one too...I think youre getting your best value there...you dont have to change the gears as the engine has been changed and wont have a problem turning the 4.10's, you have $1500 in tires on there as is, SAS is $1500-$2000 usually, god knows on the roll cage, I think the swap is more even if you take the second one. I will say though, I like the looks of the first one for a "cleaner" ride myself. Both are beutiful though, great finds.
Ok guys, he went through the fuel system and replaced everything, then found a vac line that was split and went to the throttle body, it was sucking air which was what was choking out the air/ gas mix and causing the problems! so I will be picking up the green one monday!
well both of those fell through. The blue one never got back with me and the green one had a motor issue dude could not get fixed.
Now I have this offer on the table
85 pickup, shortened bed, exo cage, 1200 lb winch, dual transfer cases, 7" lift all suspension, 35 mud terrains.
Problems, leak in / at header, both front and rear chunk leaking oil. Think there are any serious issues with that or just some seals/ gaskets?
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
