Why do front wheels lock up in reverse? I
If your wheels cease to rotate when reversing, likely it's related to your brakes. I'd service them just to eliminate the possiblity and make sure the moving parts are lubricated properly, such as the slide pins on the calipers. Also make sure your calipers themselves are in good condition, they may need to be rebuilt/replaced depending on how many miles on the rig. I'd also flush the brake fluid and when you install everything make sure to use the "M" spring clips that spread apart the brake pads when you're not braking.
Never heard of the steering rack causing a tire to not rotate, dunno how it's even possible as the steering parts are independent of the rotating assembly at the wheels.
Dekri
Jun 23, 2005 03:35 AM
futurerunner
12
Apr 25, 2005 08:55 AM
yoda92
10
Jul 18, 2003 05:51 AM
