Featured Rigs Check here to see past rigs of the week
Featured Rig for the week of 9-04-06 (SteveO)
Old Sep 4, 2006 | 11:27 PM
Cebby's Avatar
Our featured rig for this week is contributing member Steve O's ride.
<EMBED src=featured_rig/09-04-06/yt-featuredrig.swf menu=false quality=high wmode=opaque scale=noscale WIDTH=448 HEIGHT=336 TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash"></EMBED>
1999 V6 4Runner Limited 4WD, Auto (click NAV buttons for more pics)
<table width="100%" border="0" cellspacing="0" cellpadding="0"><tr><td>&nbsp;</td><td width="448">
<u>Drivetrain:</u>
<li>Stock 3.4L V6</li><li>4spd Automatic Transmission</li><li>Multi-matic transfer case with Full time 4WD</li><li>Downey Cone Air Filter Charger</li><li>Automatic Transmission cooler</li><li>High-Angle Front Driveshaft with CV on top end</li><li>Tom Woods 1/8" wall Rear driveshaft</li><li>FrontRange Off Road Transfer case mount</li><li>Optima Blue Top Deep Cycle battery</li><li>Painless Circuit Boss for Dual battery setup</li><li>Optima Red Top mounted above rear axle in a custom bracket</li>
<u>Front Suspension & Axle</u>
<li>'87 Grand Wagoneer Axle with Crane Diff cover</li><li>Yukon 4.88 gears with ARB Air Locker</li><li>Yukon 4340 Chromoly Inner and Warn 4340 Chromoly outer axles</li><li>Longfield super joints</li><li>Warn Premium hubs w/hub fuses (these work very well)</li><li>'76 Flat Top knuckles, milled drilled and tapped by Parts Mike</li><li>Spicer Ball joints</li><li>Custom Steering stabilizer mount with Rancho Steering stabilizer</li><li>Custom Pan-Hard mount and bar with 5/8" Rod-Ends</li><li>14" Sway-a-way shocks 2" diameter w/Eibach 14" lower and 10" middle coils</li><li>6" Tender leafs</li><li>Custom strut brace and BTF Shock mounts</li><li>Sky Manufacturing plates for frame braces</li><li>Custom bump stop mounts</li><li>Limit Straps</li><li>Extended stainless steel-braided brake lines</li><li>Custom bottom links, 2" .250(~1/4" thick) wall, sleeved with 1.5" .250 wall</li><li>Custom single top link, 1.5" .250 wall</li><li>Custom rubber bushing link mounts on axle</li><li>Currie Johnny Joints on frame mounted links</li><li>Custom removable cross member for 3 links</li>
<u>Steering:</u>
<li>Flaming River Steering shaft</li><li>'94 IFS Steering box</li><li>Bentup High-pressure steering hoses</li><li>In line Power Steering Fluid cooler</li><li>Parts Mike Drag link (Hi-steer)</li><li>Parts Mike Tie-Rod</li><li>Parts Mike Tie-Rod Ends</li><li>Parts Mike Drop Pitman arm with large GM taper</li><li>Parts Mike 1.5" thick Super Arms</li>
<u>Rear Suspension and Axle</u>
<li>All-Pro 5.5" leaf spring packs (ripped out the coils)</li><li>All-Pro Johnny joint rear shackles</li><li>Custom extended rear bump stops</li><li>Factory Locking diff</li><li>RORE rear locker actuator guard</li><li>All-Pro diff guard</li><li>Rancho 9k adjustable shocks, mounted on top of the axle</li><li>FrontRange Off Road Full Floating Axle kit with Moser 4340 Axles and Disc brakes</li><li>Custom track bar with Johnny joint</li>
<u>Body:</u>
<li>1" Roger Brown Body Lift</li><li>Custom front tube bumper with winch tucked in tight</li><li>Warn 9k winch w/ synthetic rope and custom security lock to prevent free spool of winch line</li><li>Winch has engine compartment mounted relays and cabin Remote controls with safety switch</li><li>Off Road Solutions Rock Sliders</li><li>Custom rear Ghetto rear bumper</li><li>Centramatic wheel balancers</li><li>Goodyear MT/R 37x12.5x15 wrapping 15x10 Unique Black Rock Crawler wheels</li><li>Confer Roof Rack</li><li>Turn signals moved to Parking lights location</li><li>Custom Gas tank skid plate</li>
<u>Interior:</u>
<li>Center console Kenwood MP3/CD/XM player with Auxiliary port</li><li>Center console mounted Cobra CB w/ a Wilson 1000 antenna</li><li>Center console inline SWR Meter</li><li>Electric Line Lock for rear brakes</li><li>Dash mounted Inclinometer</li><li>Dash mounted GPS</li><li>Remote Winch rocker switch</li><li>Dual Battery switch with Dual Battery Digital Display</li><li>ARB pump and Front locker switch</li><li>Power Tank mounted in bracket near rear door</li><li>Leather seats</li>
</td><td>&nbsp;</td></tr></table>
<table><tr>&nbsp;</tr>
<tr>For more info, see <a href="https://www.yotatech.com/forums/showthread.php?t=93179">Steve O's Check out my Truck thread.</a></tr></table>
icentropy
Sep 16, 2020 02:47 PM
94ofCanada
Aug 14, 2015 06:37 AM
andrewtexas123
Jul 23, 2015 11:22 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
