FJ Cruiser 2007 & on
FJ Cruiser MPG
Old 08-08-2006, 08:57 PM
sbechtold's Avatar
My FJ specification:
A/T
Roof Rack
4WD
ARB Bumper + M8000
OME 3" lift
285/70-17 MT/R's
Highway: 17 MPG
City: 15 MPG
Before the modifications I was getting 20 HWY and 17 City.
Old 08-09-2006, 05:21 AM
FJon22s's Avatar
who has a 4X2 and what are they getting for mileage?
Old 08-09-2006, 07:10 AM
FJ40's Avatar
Originally Posted by airrikk17
for what its wrth i ran a tank of 91 from chevron, and on the freeway only got 14.8 mpg, im not sure if it was the wind or large rack i had on top, but on my way back home on mid grade , i beleive 89 octane from chevron i got 17.2. ive been afraid to try 91 octane ever since. i was going west on i 84 from tri cities to the dalles, when i got the bad gas milage and east on i84 when i got the good gas milage with the same rack.
most recently , ith out the extra rack on , i got 18.8 on the same route, with mid grade going east and west. also i had my a/c on both trips. i drive 5 over the speed limit and usually never have to touch the gas , going up hills or down , gotta love the vvt.
airrikk17
I guess I'm one of the lucky ones. Never get less than 18.5 mpg at 80 mph. This is on I84 through the pocono mtns, many steep inclines and with A/C running. On really long trips I get 20.5 mpg same speed. However, I do not have a roof rack which probably makes all the difference.
Old 08-09-2006, 07:24 AM
ravencr's Avatar
If the engine is designed for high octane fuel from the factory, I would recommend using it. If it's not, you won't see probably any gains from running it. The reason is that the higher compression ratio and timing curve of the FJ's require a higher octane fuel to keep it from detonating. The knock sensor will detect it, so if mid grade or low grade fuel is used it automatically retards the timing to adjust, but this is when you lose power and fuel efficiency. To maximize both efficiency and power, run the higher octane. On the 3.4 Liter engine, it makes or provides no benefit, because the engine doesn't need it.
Chris
Old 08-09-2006, 09:35 AM
  #25
Toyota Punk's Avatar
Originally Posted by Corey
Hmmmm...
Thanks Bob, I may switch back to Union 76 again, even though I get 6 cents off every gallon at Safeway if I spend $50 a week on vittles which is very easy to do.
Too bad there's no Giant Eagle stores out there. We get 20 cents off per gallon for every $50 spent at the grocery store. Problem is there aren't many Giant Eagles with a gas station attatched. You've got to drive a bit to find one.
Old 08-09-2006, 09:59 AM
  #26
FJon22s's Avatar
Anyone with a 4X2
Old 08-13-2006, 11:04 AM
  #27
Co-Founder/Administrator
Staff
Corey's Avatar
Went up again today.
Combined city/freeway driving, no jack rabbit starts:
First tank
17.5 MPG
Second tank
19.567
Third tank
20.0865
I am going to break 21 to 22 or better after the engine breaks in (5K I hear) and when I switch over to Amsoil synthetics I bet.
Old 08-13-2006, 05:45 PM
  #28
BT17R's Avatar
Please be more specific.
What brand and octane fuel?
No question that the taller geared A/T's get better economy above EPA ratings based on your and other's experience.
Yeah, the 1GR will take at least 5K to break-in I've heard. But, once broken in properly, should be a 300K motor, prolly more with Amsoil.
Old 08-13-2006, 06:06 PM
  #29
Boaz's Avatar
FWIW my 1GR-FE started getting the best fuel mileage around 15k.
Old 08-13-2006, 06:21 PM
  #30
Staff
Corey's Avatar
Here ya go Bob
http://www.pnw4runners.com/index.php..._mpg_maint.xls
Old 08-20-2006, 05:22 AM
  #31
Staff
Corey's Avatar
Almost hit 21 today
First tank
17.5 MPG
Second tank
19.567
Third tank
20.0865
Fourth tank
20.7855
Cool how it goes up a bit each week, even with me getting more agressive with the go pedal.
Grand total of 673 miles on it now.
Old 08-26-2006, 11:05 AM
  #32
20Montana's Avatar
A/T, Roof Rack, 4WD.
I have checked 3 tanks so far, 91 octane, and I am getting 20 consistently. I am up to 920 Miles on the odometer. Hopefully it may even do better after breakin.
Old 08-26-2006, 11:20 AM
  #33
91_4x4runner's Avatar
How large is the tank on the FJC?
Old 08-26-2006, 11:59 AM
  #34
20Montana's Avatar
19 Gallons.
Old 08-27-2006, 05:19 AM
  #35
Staff
Corey's Avatar
First tank
17.5 MPG
Second tank
19.567
Third tank
20.0865
Fourth tank
20.7855
Fifth tank
20.7988
Just a microbe hair better than last week.
I will break to 21 or 22 once I change to Amsoil and after 5K on the engine.
Old 09-06-2006, 09:51 AM
  #36
motoracer47's Avatar
people have kinda touched on it, but not really addressed it. active knock control. the ecu im most conditions, including cruise, will try to run the engine with as much ignition advance as the knock sensor tells it it can. this increases fuel mileage because it makes more use of the pressure generated in chamber because of crankshaft position. there is an optimum, and you can advance too much. basically, 91-93 octane will allow the ecu to run the timing right were it wants to, 87 octane will cause the ecu to pull timing, lower power and efficiency=fuel consumption.
btw, i think most toyotas dont achieve their max fuel efficiency till after 3k or so.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
TheBFA
02-15-2020 06:55 AM
primordialbeast117
12-19-2015 12:23 PM
4runnerFireman
09-29-2015 06:24 AM
Aaronmarston
09-22-2015 09:39 PM
Quick Reply: FJ Cruiser MPG
