FJ Cruiser MPG
Co-Founder/Administrator
FJ Cruiser MPG
Not that I care what I get for miles per gallon, if I did I would not have bought an FJ Cruiser or any Toyota SUV or truck for that matter, I would have bought an econo-car.
Just curious what others are getitng.
Specs:
auto tranny
roof rack
4WD
stock size tires
Combined city/freeway driving, no jack rabbit starts:
First tank
17.5 MPG
Second tank
19.567
Almost a two mile per difference on the second tank.
I think the dealer used regular grade on my first tank.
Last week I filled up with super premium, and on my third tank here I filled up again with super premium, 91 octane.
Better mileage with the higher octane.
Specs:
auto tranny
roof rack
4WD
stock size tires
First tank
17.5 MPG
Second tank
19.567
Diesel is two years away.
Not Toyotas fault, it is the USAs fault.
The Toyota diesel is designed to run on a better diesel fuel than the US has right now, I think it is called bio diesel or something like that.
All other counties have it, so they get diesels in their Toys.
When the US gets its act together with the new fuel in all of the states, Toyota will ship rigs with diesels over here.
Corey, why does premium get you better mpg? I thought as long as the car/truck has a knock sensor, there was no point of putting fuel rated higher than what would not cause the car to knock? Not saying what you said is false, just trying to get more info...
I do not know why it does, but reading this info over on another FJC forum netted that it does.
The difference between regular and super is not worth it to me to skimp, I think it is $100 a year or so?
I would have to calculate it out.
You get a little more power and MPG with the super from reading tests, so that is what I will try for awhile.
Anyway, thanks and hijack off...
The FJ cruiser does have a knock sensor, most new vehicles do. According to Toyota you're supposed to run premium from the factory, at least this was the initial official statement. The 4.0 as it sits in the FJ is tuned for premium, but can run on lower octane fuels, it just won't run as well.
Originally Posted by 2jmotorsports
Not 100% sure but maybe the variable valve timing comes into play to take advantage of the premium gas? Might give it a shot on my Tundra...
...I find it funny in a "that actually kinda sucks way".
Corey, I'm getting 15-16 City, 19-20 Hwy on Chevron Supreme 91 and Mobil 1 5W-30. I drive moderately aggressively, about 80% on two-lane mountain roads between sea level and 4,000 ft., temps between 60 and 105, A/C on 100%, A/T tires at 35 psi all around.
The 1GR has a knock sensor on each bank. I don't think Regular would harm the engine, but it wouldn't develop max power either. The one tank of Regular I ran (gas jockey error), I heard detonation when accelerating at WOT in 1st gear from a standstill done as a test. It was brief but audible. Since then it's been Premium only for me.
Doing the math based on 15,000 miles/year and 20¢/gal more for 91 and a conservative 16 mpg, it would cost you $187.50 more for Premium and about $10/year less for each mpg increase above that. Worth it, IMO, and whatever you do, please stick with Tier 1 fuel, currently Chevron, Shell and 76 on the West coast.
Bob, on the tier one fuel, any idea what the local Safeways up here are using?
I use to use 76 all the time, but since Safeway put in a fuel barn here at the store I shop at, I just get gas there, then park and go inside to get the vittles for the week.
The Chevrons and Shells here (a few right by Safeway) are generaly 5 cents or more for 91 octane.
I have had good luck with Safeway, but I wonder where it comes from.
Also I should see an increase from that 19.5 I just got after the engine breaks in and I switch over to Amsoil synthetic in the future.
Corey, FWIW I have over 50K on my 4.0 L. I have kept pretty good track of the gas milage for about the last 30k, I have run high octane about 10 times and noticed no difference in power or MPG. I average about 17-18 CIty and 21-23 Highway. In my experience its just not worth it to pay for the high octane gas. I put the cheapest 87 octane I can find in it and drive the hell out of it.
Corey, when I asked them at the Safeway station a few months ago, they didn't know either. It's delivered in unmarked trucks. It wouldn't have the proprietary additives like Techron or V-Power exclusive to the other brands, and AFAIK makes no Tier 1 claims.
Corey - you might want to ask at the 76 station - the one up here in Bothell has a "super tuesday" special that is unadvertised - $0.05 (there is no cents key anymore!) off every tuesday - most of the locals know it and I see the same performace rigs in there all the time. That coupled with the fact that they are usually the the cheapest around makes it worthwhile.
Hmmmm...
Thanks Bob, I may switch back to Union 76 again, even though I get 6 cents off every gallon at Safeway if I spend $50 a week on vittles which is very easy to do.
for what its wrth i ran a tank of 91 from chevron, and on the freeway only got 14.8 mpg, im not sure if it was the wind or large rack i had on top, but on my way back home on mid grade , i beleive 89 octane from chevron i got 17.2. ive been afraid to try 91 octane ever since. i was going west on i 84 from tri cities to the dalles, when i got the bad gas milage and east on i84 when i got the good gas milage with the same rack.
most recently , ith out the extra rack on , i got 18.8 on the same route, with mid grade going east and west. also i had my a/c on both trips. i drive 5 over the speed limit and usually never have to touch the gas , going up hills or down , gotta love the vvt.
airrikk17
airrikk17
Gas milage
Just returned from Colorado with my new FJ.
Auto
Roof rack
2WD
rock rails
Kept it at 65 mph on the way out from eastern Kansas. 21.3 mpg on the way out. Intown only I'm about 17.5 to 18. I'm older so I'm a little slower off the green which I'm sure helps.
It was a mountain goat on the trails in the mountains. Much nicer plateform than my 4Runner.
The head mechanic at the dealership said 91 octane was no big deal. I would beg to differ.
Auto
Roof rack
2WD
rock rails
