Driver's rear spring sagging problem OME 3"
Does anyone else have a problem with the driver's rear spring/suspension sagging? When I put in a full tank of gas, the driver side rear is 1 3/8" lower than the passenger side. OME 3" Medium lift on 2007 FJ. I did call ARB and they said that the springs are the same on both sides so there isn't a driver side specific one.
Co-Founder/Administrator
I have the heavy duty OMEs up front, and the mediums out back, and I am even.
I have read that some do have this leaning problem with theirs.
I would stop in at ARB since you are close to them (I also work just down the road a mile from them) and see what they have to say.
You can check in on the 5th gen 4Runner they are setting up for overland travel too.
PS, you might ask ARB about this if you stop in to talk with them.
ARB spacers
http://www.fjcruiserforums.com/forum...body-lean.html
ARB spacers
Thanks Corey. Talked with them today and they are setting up an appointment with me next week. They are in the middle of building a show rig so that is the quickest they could get me in. I did ask about the spacer aspect, and they explained a lot about that to me. I will relay the rest after speaking and seeing them.
Thanks again.
Thanks again.
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
icentropy
Jul 11, 2015 07:21 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
