FJ Cruiser 2007 & on
ABS Bypass...
Old Mar 18, 2010 | 12:53 PM
TRunner's Avatar
ABS Bypass...
So what's it take to get the ABS system turned off? I want a button for this...
Old Mar 18, 2010 | 04:29 PM
RobD's Avatar
If I was inclined to disable ABS, I'd probably look for the ABS fuse that runs either the ABS pump or ABS computer (assuming that it's not integrated in your ECM).
Then I'd possibly consider putting a switch or a switch/relay combination in-line with said fuse.
Old Mar 19, 2010 | 05:18 PM
TRunner's Avatar
I'm hoping it is this easy... But I doubt it.
Old Jun 15, 2010 | 06:35 PM
toyo22r's Avatar
Actually, yes it is quite easy. See my hack here.
http://www.fjcruiserforums.com/forum...ta-switch.html
Not only does it disable ABS, but TRAC and VSC. Nice to be able to turn off all the nannies.
Old Aug 22, 2010 | 04:31 PM
martinfan30's Avatar
This is spooky business, but I can understand the desire to disable the "STAR" system in certain conditions.
Just be aware, if an accident occurs... You will be liable for damages if it's found the "STAR" system has been disabled.
JimiJams
Sep 28, 2015 06:14 PM
BimmerSage
Sep 17, 2015 11:48 PM
BimmerSage
New York
Sep 17, 2015 05:21 PM
matt1833
Sep 16, 2015 07:11 AM
zz_denis
Sep 6, 2015 03:43 PM
