93-98 T100s All T100 trucks
Shaking/Vibration from stop
Old Dec 21, 2013 | 03:52 PM
CPLJEG's Avatar
My truck vibrates/shakes when I let the clutch out/accelerate from a dead stop. It does not do it when shifting gears or cruising. I just replaced the clutch and all associated components about 1,000 miles ago. I cannot feel any vibes in the clutch pedal or gas pedal. The shaking is pretty significant, makes the whole truck rattle and is noticeable watching the truck from behind. I've checked and greased the u-joints and they don't have any play, the center support bearing has about a 1/2 inch of play. I was thinking it could be the u-joints in the cardan joint or maybe even a flange bearing. I'm pretty mechanically inclined but I've never messed with drive shaft components, any insight, advice, or tips before I take it to a mechanic would be appreciated. Thanks in advance.
Old Dec 23, 2013 | 10:02 AM
250000_yota's Avatar
When you replaced the clutch, did you have the flywheel machined/replaced? If not, it could have hotspots in it, causing chatter. That, or the clutch disc could have been contaminated with oil somehow. When I did my first clutch in my T, I used a factory toyota clutch. Toyota ships their pressure plates soaked in oil to prevent rust, which I continently forgot. Just about 1000 miles later, the clutch started chattering. I was able to minimize it by removing the boot around the shift fork and blasting brake cleaner into the clutch with it running, but like I said, this only minimized it. I had to do another clutch after 30k of it chattering on take off.
I wouldn't suspect a u-joint because usually, you would feel the vibration at higher speeds, not on takeoff.
TheBFA
Feb 15, 2020 06:55 AM
Alexdosdall
Dec 10, 2017 05:48 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Scotttekoch
Sep 28, 2015 10:30 PM
gentry
Sep 28, 2015 06:16 AM
