Runs Rough Injector Problem?
96 t100 with a bout 145K miles. It starts up good, runs and drives good until I stop and let it sit for about 20-45 minutes. It takes a couple tries to start it, but as soon as it starts it runs really rough, and then will die out if your not careful. If I rev it up a few times it all clears up in a bout 2-3 minutes and then will proceed to run good the whole day unless I let it sit and try to start it after 20min. Now if it sits longer than a few hours it runs normal after startup. My first thought is there is an injector leaking and after it sits for the while the fuel finally stops leaking and evaporates. Any ideas on what could be the problem? Any help would be appreciated. Thanks.
burninggraphite
Oct 24, 2016 10:17 AM
GoldenBeaR6
Dec 11, 2013 06:26 PM
code1p36
Oct 31, 2011 07:46 AM
cjlabonte
Feb 28, 2010 04:36 PM
