93-98 T100s All T100 trucks
Replaced headgaskets now running hot
Old Sep 2, 2014 | 04:38 PM
Gctb1289's Avatar
I replaced the head gaskets on my 5vzfe and now when it is started it is overheating. I did put a new thermostat and water pump and timing belt in at the same time. I do also have an oil leak from the oil cooler but have gaskets I have to install for that. Dumb question but people have been telling me that the headgaskets were installed backwards then. Is that even possible on this motor?
Old Sep 2, 2014 | 04:41 PM
rworegon's Avatar
Did you get all the air out of the cooling system? Burping we call it 'round here.
Thermostat jiggle valve in the 6 o'clock position?
Old Sep 3, 2014 | 10:54 AM
Gctb1289's Avatar
how would you get all the air out of the system? I will check the thermostat tonight when i get out of work. the radiator and thermostat where new and given to me when i got the truck replaced the radiator but didnt replace the thermostat until i did the head gaskets.
Old Sep 3, 2014 | 05:23 PM
rworegon's Avatar
Under what running conditions is it overheating? Needle going high? Other?
Did you fill the block with coolant through the upper radiator hose?
To burp, get the radiator at the highest point in the system, remove the radiator cap, and start the engine...the idea is as the thermostat opens any air gets pushed out the through the open radiator.
Also, be sure to fill the overflow expansion tank to the cold mark with coolant.
Old Sep 3, 2014 | 08:49 PM
BamZipPow's Avatar
The head gaskets are indexed fer left and right. They are not interchangeable but they can be installed on the wrong head. The head gaskets should've been marked as such.
Spicer
Apr 7, 2026 07:17 PM
sonic concepts
Aug 16, 2025 03:13 PM
Team420
Jan 12, 2021 04:57 PM
B. Graves
Jul 3, 2015 04:10 AM
serenity03k64
Jun 27, 2015 07:59 AM
