93-98 T100s All T100 trucks
Is the rear axle/differential housing the same for a 1996 and 1995?
Old 12-11-2018, 01:42 PM
chrisxskis's Avatar
I know the ratios are different, but is the driveshaft length and tailpipe hangers the same?
Old 12-11-2018, 03:02 PM
millball's Avatar
Originally Posted by chrisxskis
........ but is the driveshaft length and tailpipe hangers the same?
Huh???? What do either of those things have to do with an axle housing?????
Old 12-12-2018, 04:14 AM
chrisxskis's Avatar
Clarification
Sorry, I guess I should clarify what I am trying to achieve. The axle/differential cover has rusted through and I need to replace the entire housing. Is the actual housing the same on the 1995 parts donor so that I can take the guts out of it and reinstall the guts of my 1996 into the housing of the 1995?
Old 12-12-2018, 05:09 AM
millball's Avatar
SIGH.........You don't name the model of either your machine, or the donor, but very probably NOT>
See this for some info:::::http://home.4x4wire.com/erik/diffs/
Old 12-12-2018, 05:52 AM
chrisxskis's Avatar
I have a 1996 T100 2WD Automatic and the donor is a 1995 T100 2WD Manual.
Old 12-12-2018, 06:36 AM
millball's Avatar
Eriks page seems to indicate that all T-100 axles are the same width.
If both your axles, or neither one of them, are ABS equpped, looks like internals might interchange.
TNRabbit
04-14-2023 07:32 AM
arlindsay1992
266
03-05-2021 03:12 AM
gyoas759
36
06-17-2019 06:02 AM
ChildrenOfBodom
124
06-24-2012 01:17 PM
Quick Reply: Is the rear axle/differential housing the same for a 1996 and 1995?
