93-98 T100s All T100 trucks
1993 T100 automatic trans same/compatible as 95 up for 3.4 swap?
Old Dec 21, 2006 | 05:26 AM
Ric18's Avatar
Alright,I am planning on swapping in a 3.4 liter into my 93 T100, but my issue arises with the transmission (my truck obviously has the 3.0 liter). After doing some quite extensive research on this subject I have learned the manuals bolt up just fine, but the auto transmissions need to be swapped. This is at least what I read about concerning the 4runners and the compacts, but I seen somewhere else that the T100 automatic transmission is different.
My question is therefore, did the T100 have a unique transmission that made it compatible with the later produced 3.4 liter engine?
Any help some Toyota experts can give me would be greatly appreciated....
Old Dec 21, 2006 | 03:54 PM
Ric18's Avatar
Well I am buying a 3.4 and going ahead with it. I'll let everyone know how it goes...
I got the ECU and wiring harness as well...
I was communicating with someone with a 1996 T100 and his has the exact same designation as mine... This is good news.
Old Dec 24, 2006 | 03:07 PM
Froggy93's Avatar
good luck. post some pictures if u can. I am thinking about future swap ideas for my T100. in college now so can't afford it but maybe later. don't know about the bolt patterns on the trans though.
Old Jan 17, 2007 | 06:26 AM
1970xl's Avatar
Do you know how much the 3.4 weights vs the 3.0. I have a 1993 4Runner w/auto and thinking of doing the same swap. I'll be keeping and eye on your post.
Old Jan 17, 2007 | 07:14 AM
Cebby's Avatar
The T100 was equipped with the rare passenger side drop A340F (while 3.0's in 4Runners/trucks came with the A340H). I'm not certain of the reasoning, but I wouldn't assume the 96+ T100 has the same trans even though it has the same designation. I thought the reasoning for using a trans from behind the 3.4 was a wiring issue.
The good news is that with the A340F, you can easily add a crawler (before I'm corrected - yes I know Inchworm has a kit for the A340H, but it requires dismantling the trans/t-case)
Old Jan 23, 2007 | 07:17 AM
Rob_O's Avatar
I could use some pics of that tranny and transfer case combo, I'm sticking a '97 3.4 into a '95 4Runner and need a transfer case with the correct drop
Old Jan 23, 2007 | 07:35 AM
Cebby's Avatar
You can use a Marlin adapter and gear drive case behind any A340F. The adapter is for an auto to gear drive case - or you could go bananas and get a double too...
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
BeMiceElf
Oct 10, 2015 09:40 PM
taller1
Jul 16, 2015 03:00 PM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
