General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Where to buy single pair wiring to lengthen O2 sensor?
Old Dec 27, 2009 | 05:01 PM
Zelephant's Avatar
I'm about to install a new exhaust in my 'Runner, and I need to move the cat, and thus the O2 sensor, back 8". The wire for the O2 won't reach back that far, so I was told to lengthen it with "single pair wire". My question is, where can I find single pair wire? Is there another name for it that I don't know? Is there somthing else I can use to lengthen the O2? Thanks!
Old Dec 27, 2009 | 05:09 PM
RMA's Avatar
RMA
get a long piece from a junked car at a junkyard , Maybe !!
Old Dec 28, 2009 | 03:00 AM
Wardamneagle's Avatar
There's nothing special about the wire. "single pair" I think just means two insulated wires (either stranded or solid) in one insulated "wire". For example, romex (normal house wire) could probably be called "single pair with a ground".
Just look at the wire size and go to HD or Lowe's or the local parts house and get a two conductor (my O2 sensor is only one conductor, btw) wire of the right size (or larger) and splice it in. I'm guessing it's 16 or 18 gauge.
Old Dec 28, 2009 | 09:25 AM
4Crawler's Avatar
Looks like O2 sensor wire extensions are available:
- http://www.google.com/custom?domains...wire+extension
I know on my 1-wire '85, the O2 sensor wire is one conductor with a grounded shield around it. On the 4-wire vehicles, you have 2 additional power wires for the heater.
Old Dec 28, 2009 | 03:13 PM
Zelephant's Avatar
Ok thanks guys, that helps a lot! I'll have to see how many wires mine has.
Old Dec 29, 2009 | 12:08 PM
You might be right but my 85 is not that way. When I installed my LC Engineering header and exhaust system the package included an extension "kit" for the O2 sensor. It was basically nothing more than a length of wire and a couple of splice connectors. It was one conductor with normal insulation. There was no grounded shielding.
moparbay
Mar 10, 2023 03:50 PM
some drunk guy
Aug 3, 2021 06:09 PM
shredder4286
Oct 1, 2015 01:09 PM
Boomer8404
Sep 24, 2015 01:12 PM
sonorn67
Sep 19, 2015 05:39 PM
