General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
where to buy power wire from battery to engine fuse
Old Feb 5, 2013 | 02:18 PM
bttrs's Avatar
in the process of dealing with other problems i was lead to the power wire from the battery to the engine fuse in the engine bay fuse box. i was pulling the engine fuse out to try and check for bad connections when the end of that wire broke free from the plate its originally mounted to. wondering if anyone has bought one of these before from anywhere if toyota maybe has them?? any help would be great i just dont want to replace with another 20+ year old used one
Old Feb 5, 2013 | 02:21 PM
snobdds's Avatar
Dealer or make your own...
Old Feb 5, 2013 | 04:27 PM
nightstalker's Avatar
I built mine from napa parts store stuff, its cheap and easy
Old Feb 5, 2013 | 04:38 PM
bttrs's Avatar
did you replace the fuse box end of that power wire though? if it wasnt for that 1.5x1.5inch peace of flat copper i would jump on making my own.
Old Feb 5, 2013 | 05:23 PM
snobdds's Avatar
I guess I am confused on what wire your talking about. Here is a diagram...
If it's the wire into the diagnosis box, then that should be part of the wiring harness.
Old Feb 5, 2013 | 06:06 PM
vital22re's Avatar
totally a bro
The fuseable link on earlier models. you can just crimp or solder on a ring terminal and bolt it in using one of the bolts that are holding the other wires to the plate.
rbravo1
Jun 29, 2015 01:34 PM
odonekanobe
Jun 26, 2015 02:27 PM
Corey
Jul 7, 2002 01:32 PM
Corey
Jun 25, 2002 11:13 AM
