turns over but wont start
i have a 1981 4x4 pickup that will not start. ive got fuel pressure and spark from a brand new coil pack but it don't sound like any spark is getting to the spark plugs. any ideas what to do to fix it????
Cap and Rotor wires while your at it plugs as well.
Is the Rotor turning??
You have not Checked for spark at the plugs??
Just how did you get to this Crank but no start condition
81 22R ??
Just where are you measuring Fuel pressure ??
81 22R ??
Is the Rotor turning ??
Could be just old age how many miles ??
Sheared off crank or cam gear.
Broken timing Chain
Then do you have zero compression or just very low.
My one 22RE engine I could spin with one hand on the crank pulley with the plugs in.
It still started and run although power was on the low side .
Broken timing Chain
Nineonerunner
May 5, 2022 10:20 AM
