General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
turn signals... kind of psycho
Old Nov 18, 2009 | 05:14 PM
cgeorge's Avatar
OK - this is more of an annoying issue that my wife calls the truck's psychotic turn signals.. :
When I use the turn signals - they blink normal for about 3 or 4 intervals.. then they speed up.. slow down... speed up...
it is kind of funny and it passes the state safety inspection but it is crazy and I'd like to fix it. I searched around and didn't see any other posts that referred to this but I suspect it is the flasher/turn signal relay?
Old Nov 18, 2009 | 05:27 PM
stockwell45's Avatar
the only way to find out is by replacing the relay. that makes the most sense to me
Old Nov 18, 2009 | 05:49 PM
4Crawler's Avatar
X2 on the flasher relay. I had a similar issue in my VW, would flash normal, faster, slower, some times not at all. Put in a new flasher and all is well.
Old Nov 18, 2009 | 10:51 PM
ISLANDER 80 CRUSHER's Avatar
Before you change the flasher relay, just make sure all lights and wires are not loose. I did that on my Sequoia and Landcruiser and both were bad bulbs and a loose wire on the L/C. Just trying to save you some $$$.
Old Nov 19, 2009 | 03:17 AM
cgeorge's Avatar
thanks for the tips.. I checked the bulbs and wires last night.. I think it is the flasher since those were all OK..
jashoeuh
Nov 18, 2024 08:08 AM
Liadrin
Apr 25, 2022 02:54 PM
jasonty
41
Dec 23, 2018 01:00 PM
theking11863
Mar 19, 2016 09:36 PM
Liadrin
Sep 1, 2015 06:44 AM
