Simple Wiring Question, please
Front and rear parking lamps are out as a result of a fuse blowing. Every subsequent fuse has blown immediately. I know this is a short. My question is - could a broken ground wire cause the short? If there is no ground, will it pop a fuse?
Try simplifying things, pull all the bulbs and re-test the fuse. Could be a bulb in which the filament shorted internally (it has happened before).
Also, did you do any wiring mods lately, such as a new radio, amp, etc. or a trailer wiring harness? If so, check all those things and/or disconnect those parts and re-test.
The internal short on a bulb is a good idea. I'll try that tonight.
THANKS FOR ALL THE SUGGESTIONS!!!
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
