Searching for new short
OK, I am technical and should be able to figure this but still need help.
I was installing an aftermarket DVD/TV in my 04 Sequoia. Thinking it was a good idea and save me time I attached the constant, ground and door trigger wires from the DVD player to the dome light wires. Worked for a VERY short time. Blew the 10amp dome fuse in the engine compartment so disconnected DVD to wire direct to battery (
Like I should have in the beginning) but now I have caused a short in the dome circuit.
Here are the steps I have done and where I am.
After I blew the second fuse I did continuity test and found truck side of the fuse was shorted to ground
Removed the fuse block under the driver side. Check continuity of red and white wires from dome to white connector OK, white connector to engine fuse is OK.
Check for short every time I plugged a connector back into the fuse block. The black connector on the top left side was the last one, Yep short.
Also, disconnect (+) from battery no short, reconnect battery and short reappears, so I know it is in one of the active components.
My wife
found the keyless entry didn't work any longer either. She has refused to drive it till it is fixed
Tonight I found the clock does not keep the time. When you turn the truck off the clock resets to 1:00 and the AC resets as well
Does someone have any ideas, the diagram for the circuit and I also am looking for the pin out for the black connector on the top left of the fuse block.
Help?
My wife
Help?
montanatruck
Feb 26, 2017 07:07 AM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
129Creepin
Aug 5, 2015 10:12 PM
landrunner
Aug 5, 2015 09:18 PM
