General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Reverse light always on
Old Oct 23, 2009 | 11:35 PM
YFZsandrider's Avatar
Just bought a '94 pickup, and among other issues from the previous owner, my reverse lights are always on. Before I get under there and start digging around, are there any usual causes for this?
Old Oct 23, 2009 | 11:46 PM
turboboost's Avatar
Check the plug on the side of the transmission. Sometimes the wires short out against each other which makes the truck think it's in reverse.
Old Oct 24, 2009 | 07:37 AM
4Crawler's Avatar
Or the reverse switch may be stuck on. Simple test is to unplug the connector there, like noted above, and if the lights go off, then the wiring is fine but the switch may be bad.
Old Oct 25, 2009 | 05:20 PM
bugs1961's Avatar
Changing the switch is very simple: unplug the connector then unscrew the switch and put a new one in. You need a 27mm socket or wrench, or a large adjustable wrench. It shouldn't be too tight.
The switch is on the passenger side of the transmission, fairly high. It's the only electrical component in that area.
AkitaDog
Sep 1, 2015 08:05 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
