General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
replacing wiring harness plugs
Old Jul 23, 2006 | 05:58 PM
DN1911's Avatar
anyone know if the connection for sensors and injectors, ect. can be replaced? i found several that were broke while removing fuel injectors and intake manifold today.
Old Jul 23, 2006 | 07:30 PM
Elton's Avatar
shouldint be to hard just a matter of finding good ones and cutting them off and soldering them back to gother
Old Jul 23, 2006 | 07:42 PM
wjwerdna's Avatar
anything can be replaced, as Elton said, you just need to cut a lot... what vehicle do you have, I may have part numbers
Old Jul 24, 2006 | 01:47 AM
dz's Avatar
dz
if you can dig up just the connector bodies, you can remove the wiring (including pins/sockets) from the connectors and replace them without cutting, assuming everything else is still good. Just need a removal tool (read: piece of plastic the right size)
Old Jul 24, 2006 | 12:41 PM
DN1911's Avatar
the truck is an 86' with a 22RET. i figured the turbo specific parts would be hard to find.
Old Aug 6, 2006 | 10:50 AM
Tragic Drive's Avatar
This reference file doesnt apply to your (86) truck however it can help with the procedure of replacing the connectors. I would pull the pins out of the existing harness and install them in a known good plug. Take notes and pictures if you go this route.
Ok, so here is the LINK and there is some great info here for all. Its the FSM harness repair manual for 91 to 05 Toyota's.
FOREWORD
This manual has been prepared for use when
performing terminal repairs, wire repairs, or connector
repairs on vehicles.
A step–by–step section on connector repair and
terminal repair is included.
There is a section of charts with terminal and connector
illustrations, part numbers, and notes on terminal
removal.
By using this guide, a satisfactory repair of the wiring
harness and connectors in Toyota vehicles will be easy
to achieve.
All information in this manual is based on the latest
product information at the time of publication. However,
specifications and procedures are subject to change
without notice.
,Thomas
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Regency
20
Jan 3, 2020 07:43 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
elwood73
Jul 5, 2015 07:07 AM
