General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Off Road lights mounted on roof??
Old Feb 8, 2010 | 09:46 AM
xskydivingdudex's Avatar
and to add to alexjet, a con is that one of my friends ripped off his lights bc he was offroading at my friends ranch and tore the lights completely off... though i still do plan on getting some.
Old Feb 8, 2010 | 12:17 PM
Doddy's Avatar
I have two Hella 500's coming off the back of my rack.
I ran the wires down the rack and across the factory rack to the rail (I need to get a nice weatherproof plug to replace the wire connectors but that's besides the point).
I drilled a hole through the back of the end cap on the factory rail and drilled a hole through the drain plug that is located underneath the factory end cap.
Then I ran my wires through the drain plug and along the headliner, down the side pillar, along the floor board and through the firewall and wired up the relay and everything under the hood. After you run all the wires and have everything zip tied off put some silicone in the drain plug all around the wires so that no water can get in there. I've had mine wired up for over a year now and haven't had any issues with water leaking or anything.
I got the idea on this site somewhere, so there should be a thread with a full write up somewhere.
Old Feb 8, 2010 | 02:54 PM
fightman80's Avatar
Smile
These set ups look great! I'm not sure which way to go though, I would like to have the wiring as stealthy as possible. So, I would probably go through the roof with them and across the headliner like some of you did.
I have another couple of questions for you guys. Forgive my "newbie-ness"..... What does a relay do, and why not just wire it directly with a switch and to the battery? Why use an auxiliary battery?
Old Feb 8, 2010 | 03:09 PM
AlexJet's Avatar
For a direct wiring you'd need an HD switch. Most switches can't handle over 10amps. Wiring 2 circuits help divide low current through the switch and high current to the lights. Its easier and safer. Plus you can customize by making the lights switch in different manner.
Routing via aux battery will keep your battery safe. Ideally you'd have starting battery you start your truck with and a deep cycle one for running all accessories. I prefer the second way. PM me your email and I can give you more details on my setup.
Old Feb 8, 2010 | 03:34 PM
  #25
coonhunter111's Avatar
you can solve the problem of hood glare from the lights by simply putting electrical tape over the bottom of the lights. it doesn't affect the brightness much but it definitely reduces the glare on the hood.
Old Feb 8, 2010 | 08:19 PM
  #26
bak3rme's Avatar
Originally Posted by AlexJet
Both trucks has Hellas up there. Wiring is along the A-pillar.
o man...that is one SICK looking 4th gen. are u from missisuga by any chance? those buildings look fromililar
Old Feb 9, 2010 | 02:46 AM
  #27
AlexJet's Avatar
Thank you. I hope it is...
Not really.Its Richmond Hill (North of Toronto, instead of West)
Old Mar 5, 2010 | 06:46 PM
  #28
This is just about exactly wat ive been thinking bout doing... I just ordered my proline rack so hopefully ill be getting it in the mail and up on the runner shortly.
Originally Posted by Deceptiwave
I put some $20 driving lights up on my Load warrior behind the air deflector. I just flip the deflector down when I need them.
I ran the wires along the bars of the rack back to the top of the rear hatch and then down to a disconnect behind the driver side tail light. Its nice to be able to take the whole thing off lights and all when I want to.
Old Mar 6, 2010 | 03:47 AM
  #29
fightman80's Avatar
Smile
Well, as many of you might know, I've built myself a roof rack out of discarded retail racks. I've mounted the lights to it, and now waiting to run the wiring through the roof, and down the headliner. I've got driving lights in the back, and back-up lights in the back which will be tied into the stock back-up lights.
What do you guys think?
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
