General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Odometer, ABS, VSC quit working...help!
Old Dec 31, 2007 | 05:40 AM
4Player's Avatar
Question Odometer, ABS, VSC quit working...help!
'03 4Runner V8 SR5 4X4, all stock except for a K&N cold air intake.....
Thanks for any help or suggestions, in advance.
Christmas Eve was quite a cold one here in Denver, about 8F. I did a little street driving in some light snow accumulation, nothing over the axles. The truck sat until the 26th, I go to warm it up, and the following happens:
The ABS light, both VSC lights, the E-brake warning light, and the engine warning light all remain on and illuminated after I start the vehicle and release the key! No funny sounds, no alarms, and nothing else operates out of the ordinary. So I decide to take it for a drive and everything works as normal, except: the odometer, the trip, the vehicle skid control and the ABS are not functioning, and again all the lights I mentioned remained illuminated.
I've checked all the regular looking fuses in the cab and the engine bay, but I have no way to check the bigger square box relays/fuses. There are 2 marked "ABS" in the engine bay, but I have no idea if they're bad or if they're the cause of the problem(s).
I put the truck on a lift and nothing is obviously broken or disconnected around the tranny or transfer case, but I could be missing something more "hidden".
Any suggestions or ideas for me to self-diagnose and/or fix the problem would be much appreciated, I'm currently out of work and the finances are incredibly tight. Thanks a ton, crew! Happy New Gear!
cwillard602@yahoo.com
303.717.4731
Old Dec 31, 2007 | 06:20 AM
SEAIRESCUE's Avatar
Snow, and resulting ice from car heat, may have collected at a wheel sensor and resulted in an ABS code. I could suspect, but doubt, that something happened to the speed sensor in the transfer case. Not the sensor itself but the external wiring at the connector.
I would go to a car wash and clean each wheel from the inside. You will likely find accumulated ice near the brakes/speed sensor. By cleaning the ice off, the sensor may start working. I think there is one on each wheel.
My $0.02
Old Jan 28, 2008 | 12:36 PM
4Player's Avatar
Seairescue--
Thanks, a ton, your suggestions paid off--literally! I didn't have to remove the wheels but I did visit a nice carwash with undercarriage water jets and the problem has resolved itself. Slowly but surely the speedo and odo came back, then the e-brake light turned off, then the VSC lights turned off and I haven't had any problems since. Thankfully, I didn't have to visit the dealership, the systems are working again, AND I have a clean truck. Thanks, again.
Respectfully,
C. R. Willard
kawazx636
Oct 6, 2021 03:03 PM
taraf
Sep 25, 2015 02:57 PM
matt1833
Sep 16, 2015 07:11 AM
zz_denis
Sep 6, 2015 03:43 PM
