General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
O2 sensor bad input
Old Jan 2, 2014 | 12:28 PM
InToxicOne's Avatar
O2 sensor bad input
So Im posting in regards to a recent issue. I use Megasquirt and according to the program the O2 sensor is stuck at .13v until it heats up and then once it heats up it stays dead at .8v until you give it throttle past 1300 rpms. Once you go past 1300 it flops over to .13v. I just replaced the damn thing and checked my wires. I sprayed them out with some maf sensor cleaner just to make sure there was nothing interfering with it. Didnt change it. Im guessing it might be the controller itself but I really cant tell.
Old Jan 2, 2014 | 01:04 PM
wyoming9's Avatar
Red face
Might help to know just what your working on??
Since your not using the stock system just what voltage does yours need to see??
Might also be a poor connection at the other end.
Old Jan 2, 2014 | 01:40 PM
InToxicOne's Avatar
Its on an 88 sr5 turbo pickup. The voltages should be right about the same as stock and its a single wire so no real chance of crossing it with an O2 heater wire.
Just got done checking voltages from the O2 itself. Idle its showing .8 volts which seems pretty high considering the fuel trim isnt nearly that high. Off of idle and rapid throttle spikes didnt move it much. Just got the thing so it should be new.
sandyota
Feb 4, 2021 11:16 AM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
dinks07
Jul 15, 2015 05:34 PM
