Need advice on wiring up switches to operate new aux lights
I purchased a couple of these switches a while back from a friend of mine for less than nothing: http://www.performanceproducts.com/p...g+Light+Switch
Yesterday, another friend helped me install 6 lights on my 4Runner w/ 4 of the lights being tied to one switch and the other 2 lights being tied to the other switch. (4 lights on the front of the roof rack and 2 on the back...pics will come soon.)
As you can see from the link above, these lights are designed to light up when you supply them w/ power. I did not see how my friend hooked them up, and now he's out of town for two weeks so no help there.
My problem is, when I turn the knob to the left of my steering wheel that controls the brightness of the dash lights all the way up to make everything real bright, the new aux. switch lights go completely off. But when I turn the dash lights completely off, the aux. switch lights are as bright as they can be. Another words, as the dash lights get brighter, the switch lights fade away and vise versa.
So as it stands now, I have my dash lights quite dim, just so I can faintly see my switch lights. I want to be able to run my dash lights as bright as the knob will allow without having my switch lights go completely off.
I assume this is occuring b/c the new switch lights are draining all the power. How do I correct this problem? I guess I need to trace to see where he tapped the power into for the lights on the switch to light up, but where should I tap power into to keep this problem from occuring?
Yeah I would just tap new power wire. Just trace it back from the switch, and pull that bad boy out, and go...hell anywhere, run it back to the battery if you want... Should fix it. I dont think there is anyway those switches are draining enough power....the lights maybe...but not the switches. lol.
And No, the switch lights do NOT have to be dimmable. I would prefer them to be bright at all times.
If he did in fact route the power wire it to the dimmer knob, why do they do dim when I brighten the dash lights and brighten when I dim the dash lights?
I've already got another accessory tapped into my dash clock to power its lights on, so would tapping these 2 switches into the same clock wire mess anything up?
Oh and if I avoid all this and run a tap straight to the battery, do I risk having any electrical issues? Meaning will it be okay if the switches have constant power to the actual lights within the switches?
Just get a new 12V cause I know from experience he has tapped the dimmer wire. The rheostat adjusts the power to the dash lights so as it allows more power to the dash lights it is taking power away from the other power tap that is in the circuit. As you lessen the power to the dash lights more power is available for the tap thus the lights get brighter.
That is how a rheostat is supposed to work.
Thanks
I would like the switches to light up when the key is in the ACC position.
So I just need to find a current working accessory power wire and tap both power wires off the switches into that wire correct? For example, my 2 aux outlets under my ashtray or my dash clock power wires would work correct?
The only problem I see with tapping the aux power outlets or your clock for power is that the truck would have to be on for it to work. If that is just power for the lighted switch, thats fine, but if its the power for the lights, then I see it as a problem that you won't ever be able to use the lights unless the truck is on.
just my .02
^ Correct.
The switches are designed to stay lit while the truck is ON and not just while the aux lights themselves are on. This allows you to easily find the switches at night instead of fumbling around "feeling" for the right switch to turn on.
And yes, I'm simply looking to get power to light up the switches themselves instead of the actual aux lights out front.
Oh and it would not bother me if the lights only came on when the vehicle was on. At least this way it would keep someone (or myself for that matter) from turning on the lights, then turning the truck off and forgetting to turn the lights off, thus draining my battery.
I'm fine with them working only if the truck is on.
Okay, I've got another idea. I would rather have my new switches light up when I turn the parking lights on...or at least whenever my dash lights turn on. This way they are not lit all the time, just when I go to turn my dash lights and headlights on.
Now my question is, does anyone know which wire and where to find it to tap into so they will light up only when the dash lights are turned on?
