General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
intermittent power loss 3.0 v6
Old May 11, 2008 | 03:08 AM
backwoods_bently's Avatar
hey yall, i got a 94 yota pu with the 3l v6 and a 5 speed tranny. every once in a while i will be driving down the road and the check engine light will come on and it will feel like i lost a cylinder and i can take the key to off and then right back to on and let it jump itself off and it all resets and the light goes out and the engine runs right. any ideas? it has me pretty nervous. i have no clue what is goin on with it. thanks for any advice.
Old May 11, 2008 | 06:32 AM
Team420's Avatar
so whats the code? Im willing to bet its either 52(knock sensor) or 71(egr valve)...how many miles? do you know how to check codes? heres the fsm link http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
it explains it quite clearly. find your code and repost.
Old May 12, 2008 | 10:18 AM
hey man, i am active duty military and im deployed right now. i wont be home for another 2 months. i aint gonna be able to check it till i get home. but i will keep that in mind. do you reckon it could have anything to do with the o2 sensor? i think it is the original one. anywho, also, if its the knock sensor, does that mean that i have a knock, or just a bad sensor? where are these sensors located? are they hard to change, or are they up top where it can be done without pullin anything apart? thanks alot man.
Old May 23, 2008 | 06:39 PM
93ToyKid's Avatar
haha, nothing can be done on the 3.0 without pulling everything else apart.
mine was doing this, and it was the knock sensor. can't remember the price, but Toyota conveniently positioned it in the valley between the cylinders. under the intake. under everything else. i'm gonna straight up tell ya...its not easy to get to. another flaw of this motor. that sensor sits where water acuumulates, therefore it rusts and goes bad. not hard to change, but time consuming. good luck!
Old Oct 5, 2010 | 04:03 PM
gadberry's Avatar
Oh boy, I just found this thread and ran the diagnostic test.. Got codes 21 and 52. So looks like the heated O2 sensor and the knock sensor, if I'm reading the codes/doc's correctly. Where's the heated O2 and how much trouble is this knock sensor?
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
93toyoguy
Aug 2, 2015 07:41 PM
