Injector plug
Injector plug
Well I am trying to get this damn truck back together. The last time I was taking it apart the little clip on the injector plug broke off. Now the plug won't stay tight and it will fall off for sure as soon as I get the plenum back on.
Is there a tool to remove the end from the wire and press on another one? Don't know if that makes sense. Or do I have to go and cut one off of a donor truck and splice it into the harness? If that is the case do I solder it? Or do I crimp it? I've heard pros and cons about this too.
Any help is appreciated. This truck hasn't been running for way too long.
Jason
Jason
Since I've ripped into this engine because of a blown head gasket there has been lots of "might as well do it since I'm in here". You are probably right....I might wrap the wiring harness in some heat wrap as well...it's getting a little brittle. You know...."since I'm in there".
If the machine shop set the heads up right then I would have been driving this thing for a couple months now....
Jason
Jason
Blamalam
Mar 12, 2022 07:34 AM
Tacoma1313
Aug 17, 2015 05:44 PM
