General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
How do I get the licence plate blbs out?
Old Mar 4, 2006 | 04:19 PM
E1's Avatar
E1
Question How do I get the rear licence plate bulbs out?
1998 Limited 4R
I took both phillips out but couldn't pull the lens down. The plastic molding that goes around the whole rear tag area was in the wa it seemed? Do I need to remove it, and if so how.
Old Mar 6, 2006 | 02:21 PM
Elton's Avatar
just carefully pry out the bulb
Old Mar 6, 2006 | 03:30 PM
OutdoorLiving's Avatar
Take a small flat head screwdriver and wedge it in there between the clear plastic and the rubber gasget. Just wiggle it until the two seperate. The bulbs pull straight out.
I just did this a half hour ago.
Old Mar 6, 2006 | 05:58 PM
E1's Avatar
E1
I can't get the lens asm out it's getting caught on the rectangular 4runner trim that goes around the tag area itself
Old Mar 7, 2006 | 03:20 AM
Once you remove both phillips-head screws, the entire piece should drop down. You'll have to seperate the clear lens from the rubber gasget and the rest of the housing. I didn't have any problem reaching mine, but I was afraid that I would break it because it took a bit of force to pry the plastic from the gasget. Just give it a little more and it should give.
Old Mar 7, 2006 | 07:46 AM
E1's Avatar
E1
Cool
Thanks
kawazx636
Oct 6, 2021 03:03 PM
kawazx636
Sep 29, 2015 08:22 AM
bhaithc
Sep 17, 2015 07:53 PM
AlexJet
Sep 14, 2015 09:00 AM
