General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Highbeams
Old Jul 6, 2006 | 08:09 AM
92foreruner's Avatar
Highbeams
Hey I was wondering if anybody knew what the color of the wires coming of the highbeam switch was on a 92 4runner? I need to run a new power wire to it and there are a mess of wires I have searched online for diagrams but haven't been able to find any of the ones I need Please help I'm tired of havin to hold the switch back in the flash to pass
Old Jul 6, 2006 | 09:51 PM
Anyone??
Old Jul 7, 2006 | 03:47 AM
4Crawler's Avatar
You might have a problem with the headlight dimmer switch itself, see:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old Jul 9, 2006 | 12:16 AM
Yeah it's a fuse problem but it has nothing to do with with high beams. I just want to know how to run power to the leads on the switch
Old Jul 9, 2006 | 06:07 AM
4Crawler's Avatar
High and low beams share a common power connection. Then the switch grounds the high or low beam filament to make it turn on. So if low beams work fine and the flash mode works fine, then the problem is likely the switch, as noted above. BTDT.
Old Jul 13, 2006 | 04:34 PM
the fuse that seems to keep blowing is the dome light fuse under the hood I have checked the door pins already...but when this fuse goes my highbeams don't switch on but the flash to pass does
kyle89yota
9
Jan 3, 2011 06:05 AM
mierzwa49
Nov 29, 2009 01:21 PM
DJK-West
Mar 12, 2008 11:16 PM
