General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
High-wattage headlight bulbs?
Old Feb 4, 2006 | 08:54 PM
dibble9012's Avatar
I just found some 100/80 watt H4 bulbs (actual wattage). Any of you guys run this wattage, do you find other drivers flashing you? How I understand it is, even though the low beam on this bulb is higher than the stock high beams, its the beam pattern that counts. High beams throw light up and around, and low beams throw it straight down. So if the low beam wattage is a little higher, it won't blind people as much as an 80 watt high beam pattern?
Also, is it really necessary to upgrade the harness? I know lots of you have done that, but I calculated the amperage and a 100 watt bulb will only draw about 8 amps, and each side headlight is fused at 10 amps. I know without the upgraded harness, I might not get the full potential of the bulb, but I'm fine with that as long as it does not fry my stock wiring.
I did search on this subject, and came up with a lot of threads about the upgraded harness, and a couple threads that said some people got flashed, (that was with a 90/100 watt bulb though)
Thanks!
Old Feb 4, 2006 | 09:06 PM
L33T35T 4Runner's Avatar
kinda like working out and only working on your ankles. i would definately upgrade the harness. i have upgraded it on both my trucks and what a difference it made
Old Feb 4, 2006 | 10:01 PM
oly884's Avatar
Guest
I upgraded the harness and am running 90/130w bulbs. Makes a huge difference, and haven't got flashed at all, (I aimed them again with the new bulbs)
Old Feb 4, 2006 | 10:05 PM
dibble9012's Avatar
well, unless it will fry the stock wiring, I will just test the higher wattage bulbs to see if anyone flashes at me. Then I will upgrade the harness if I feel I am not blinding anyone
Old Feb 5, 2006 | 05:26 AM
Dr.Feelgood's Avatar
Did you aim yours downward? After my BL, new harness and 100/55 bulbs I'm getting flashed with them on low.
Old Feb 5, 2006 | 08:11 AM
Localmotion's Avatar
what kind (manufactuer) bulb did you guys get?
I cant find anything with those kind of wattages. Is the Osram just 55/60?
I plan on buying rogers harness also.
Old Feb 5, 2006 | 09:15 AM
I got mine from bulbs.com. They also have 100/80W. They do require a $20 minimum order. But 4 H4s and a couple H3s puts you over that. The manufacturer is Eiko. Not sure where to 130/90W or ever heard of 'em.
Old Feb 5, 2006 | 09:18 AM
wow, how well do they work?
They are very cheap.
Old Feb 5, 2006 | 09:45 AM
tc's Avatar
tc
Several posts on here about the reflector not handling the heat from the 130/90's. Stick to the 100/80's max.
Old Feb 5, 2006 | 09:48 AM
yea ive read that. Im just looking for a good manuf. that sells hte 100/80
Old Feb 5, 2006 | 11:07 AM
dibble9012's Avatar
Here is a link to the bulbs I plan on purchasing, 80/100 watt, and they are supposedly a bright white like the silverstars. This is for a set of three, they also have them sold as individual bulbs, but it is just cheaper to get them 3 in a package.
Old Feb 5, 2006 | 07:59 PM
...reply...
I like them. They're a clean white, bright light. Last year I replaced the stock housings with the H4 housings off ebay. They came some half-blue bulbs that looked ricey and took away from the output. But now, with the new harness from Roger Brown and the clear bulbs it's a huge improvement. It's only since I put these bulbs in that I've been getting flashed with them on low. They are definitely brighter. I'll let you know how long they last...
Old Feb 6, 2006 | 11:40 AM
anyone try these?
http://store.racinglab.com/ipfsulowbeh4.html
http://www.rocky-road.com/ipfH4.html
http://www.4by4connection.com/ipfh4sulowbe.html
are the osram bulbs the same wattage as the Sylvanias?
Old Feb 9, 2006 | 12:48 PM
Old Feb 9, 2006 | 08:25 PM
:pat:
Old Feb 10, 2006 | 01:41 PM
dibble9012's Avatar
Ill let everyone know when I get the xenon bulbs from JC Whitney, see how they compare to the silverstars I had.
On another note, does anyone know the gauge of the wires going to the headlights on a 00 runner?
Old Feb 10, 2006 | 07:31 PM
are the osram bulbs the same wattage as the Sylvanias?[/QUOTE]
Yes, they are Matt.
I just looked again. The osram are Sylvania.
Old Feb 10, 2006 | 09:39 PM
darn.
Old Feb 11, 2006 | 01:28 PM
darn.
why darn?
Old Feb 11, 2006 | 01:32 PM
well the Osram bulbs are the same wattage as the Silverstars
I was looking for something with more wattage
