General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
head lights
Old Dec 19, 2008 | 12:19 PM
aadown1214's Avatar
head lights
I put this post on the first gen thread too, but what should i make of having to re-wire my headlights and when i turn them on, the switch goes straight to brights? is this a switch issue or wiring?
Old Dec 19, 2008 | 12:41 PM
4Crawler's Avatar
Not sure if you are saying this is something you want to do or is a problem that you are having and wanting to fix. If a problem, was something changed recently? For example, if you just put in new headlights or bulbs, could be they are wired differently (high and low beam filaments swapped - have heard of this case before). If so, you can pretty easily swap the pins/wires at the headlight connectors:
- http://www.4crawler.com/4x4/CheapTri...l#SwappingPins
Old Dec 20, 2008 | 03:46 AM
aadown1214's Avatar
The genius who had the truck before me had this truck wired like a bomb. Im trying to fix most deffinitely. However it might be the bulb cause i wired both headlights the same. Passenger works fine driver is very dim.
Old Dec 20, 2008 | 07:10 AM
4Crawler's Avatar
Likely the dim side might be due to bad wiring as well. 3 terminals on the headlight bulb; low beam, high beam and a common terminal. If somehow those get mixed up, you can have a current path of low-high instead of low-common or high-common and if so, you have the low and high beam filaments in series and that puts twice the resistance in the line, letting only 1/2 the current flow and it is like you are running your headlights on 6 volts instead of 12.
Old Dec 20, 2008 | 08:52 PM
aadown1214's Avatar
Alright, I'll take a look at it. One thing i did notice was that the coloring on the wires for the passenger and driver side on this truck are actually different. Pass side has reg-green, red-blk, and red-ylw. driver has red-green, red-blk and red-wht i think.(I could be wrong). I'll probably just look at my other truck when im home for christmas and see what's what. But what you said about it being so weak makes a lot of sense.
ashersullivan88yota
Jan 18, 2022 05:37 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
