Hazards work but not turn signals
I just bought a 92 pickup a few weeks ago. In the process of doing some rewiring for the front right turn signal bulb, I managed to pull off a double whammy. I reversed the wires and put in the wrong bulb: I used single filament rather than a dual filament. When I went to test the signal, the interior indicator light came on for a split second (I think) then died. I fixed the screw ups and now my hazards work fine but my turn signals don't work at all. I checked all the fuses in the box in the engine compartment and they are all good. I also tried a new flasher module but that didn't change anything. I know they were working before I started farting around. Does anyone have any suggestions? Thanks.
^^ negative ghostrider.
The hazard and blinker flasher is the same unit.
Usually, if the hazards work, you have a signal switch problem of some sort.
Cheers.
Cheers.
06-01-2021 01:51 PM
aciorba23
06-29-2015 04:18 PM
