full time power outlet???
greetings all!
where is this full time power outlet mod I read about? Is this a mod of the existing dash outlets or the added one Chuck did? Anybody have a writeup on modifying one / both of the dash ones for full time?
Thanks!
bs
Thanks!
bs
Re: full time power outlet???
Originally posted by bsinwa
greetings all!
greetings all!
I did both. I followed this write-up to convert the existing outlets: http://www.cableone.net/marzonie/Full-Time-Power.html It's a very simple jumper in place of the power outlet relay in the fuse box under the hood.
Here's a pic -- it's the lower jumper:
BTW, yes, it does affect the rear outlet.
Another nice thing about this mod is that it can be reversed in about 5 seconds.
I also added a couple of outlets on the driver's kick panel to allow the cable for my GPS to be plugged in without hanging down the front of the dash.
There is an easier method to that. Easy enough that the Joe Smuck in electricity (like myself can do it). Simply, take out the relay. Using a pocket knife, carefully take the cover off the relay. Inside, it should be fairly simple to see that when electricity flows, the magnet contacts the anvil and closes. Simply, wedge a piece of cardboard paper (two sheets thick) between the back housing and the anvil (to remain closed loop relay).
I did this to a relay and sold it on Ebay already. I have done it since day 1 since I bought my Tundra and no effects of the battery running down yet. If you want, I can do it free for any of you, just pay shipping. PM me for details.
Originally Posted by bsinwa
greetings all!
Thanks!
bs
Thanks!
bs
http://www.bajataco.com/Full-Time-Power.html should do the trick
Aaron
I just did this to my 98 Runner, but this only affected the rear power outlet, not the one that is next to the ash tray. (pre 99's only had one outlet in the dash, not 3). Anyone know how I can change this for the front one too? I mainly wanted to do this so i could let my phone charge when my car is off....
TIA.
TIA.
TIA.
TIA.
Well I see what your saying! On the non pre99's we get an extra 2 outlets as you probably know. I would say just make it a full time power outlet by either finding another way around it or just straight up rewire it.
Aaron
i did this instead: retaining accessory pwr until door open.
instead of retaining radio, use it for power outlet.
courtesy of www.the12volt.com
The only accessory power mine retains till door open is the power windows. I wouldnt know how to rewire it to make the outlet full time... anyone have links?
I did look at the fuse box... the ones on the 99+ are different...
The mod sorta worked, but I just wanted to see if any one else that had a 98 or older tried this and found another solution...
Full time power outlet
Los,
I installed a full time power outlet in the center console of my 95. I located the outlet in what was the rear passenger seating ash tray. I am doing a write up for submission to Tech. I did take some pics of the install and would be glad to send the infor and pics if you wish and describe anything else I did during the installation. Just been too busy to submit the finished write up. Had a few issues with the camera so a few pics were not as clear as I would have liked.
I used the rear mounted outlet from a wrecked 98 runner along with some plastic from the interior, matched mine. There is just enough space under that console to put the outlet there. I wired it under the center console an out throught the firewall to my first mod, an Aux fuse panel. I would recommend this mode (fuse panel) to everyone! There will be instances in the future I'm sure where you will need one and it makes other mods very easy to provide power to. Mine is mounted to the drivers/engine side of the firewall.
The new full time power outlet works prefect and it has the flip cover so it really looks like it belongs there and it has power when its needed. It will get a full blown test this weekend when I drive dwon to San Diego with my tow sons. That was the reason I installed it so he could plug in his inverter to use his laptop on the trip
TIA.
TIA.
The cig lighter circuit has no relay... it's power goes straight through the ignition switch contacts, so that it has power with the ignition in "ACC" or "RUN" positions. There is a 15 amp fuse downstream of the ignition switch that powers both the cig lighter and the clock, but like I said... no relay, so you will have to rewire it in order to have full time power.
The easiest way to do this (although I'm not endorsing this method, because it's not the cleanest way of doing it) is to remove the "ACC" fuse from the fuse block (ensure that it indeed powers your cig lighter). Run a full time 12V supply wire directly from your battery positive post (put a 15 amp inline fuse on that line) directly to your fuse box. Put a small male spade connector on the end of the wire, and plug it into one of the sides of the socket the fuse was plugged into (must be the side of the fuse that goes to the cig lighter... not the side that goes back to the battery.) This method is easily reversible if you change your mind, but your clock (if your 98 has one) will also be powered all the time (which you may not want.)
The best way to do it, is to run the same fused wire from the battery into the cab of the truck, cut the correct wire between the "ACC" fuse and the cig lighter, and connect your new 12V "always hot" supply wire to it instead. Be careful which wire you cut, though, depending on if you want your clock to always be on or not (I would say not...) If you decide to go this way, let me know and I can send you the wiring diagram for that circuit for my 2002, and you can see if it's the same for yours.
As a first step, locate the "ACC" fuse, pull it, and see if you lose power to your cigarette lighter and clock (if you have a clock at the top of your dash) even when your key is on.
Good luck, and keep us posted on what you find out.
THanks for the info... Im taking the 4runner wheelin and camping this weekend so I wont have much time to look into this but I will get back to you soon. That sucks that I'll have to rewire it... I think Im just going to add a full time outlet like is shown in the interior upgrades forum...
But Ill let you know. Thanks again!
thelifeadventure
Jul 2, 2015 03:09 PM
