General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Fog Lights
Old Nov 4, 2007 | 05:56 PM
rowdy235's Avatar
Fog Lights
Okay so I searched and really couldn't find a definite answer to my question.
I picked up some fog lights at wal-mart to install on my truck. It was a real neat setup and came with wiring and a switch and everything. Of course, I just had to have an issue. Anyway, what I am wondering is where to wire in the lights? I've got them grounded and the switch wired to the lights, I just need to know where to connect the positive lead.
The instructions said to connect it to the low-beam wires. I really didn't want to do this because there are times when I don't want full-blown headlights, I just want fog lights on. I contemplated connecting directly to the battery, but I have enough trouble remembering turning off the lights
Anyway, I was thinking connect them to the parking lights. I have a good wire to tap off of right where my wiring runs past (side-marker) and I think that would be the ideal setup. Anybody see any issues with this plan? Thanks in advance.
Old Nov 4, 2007 | 06:06 PM
Jay351's Avatar
How could you forget to turn off fog lights at night?
you could try wiring them into the parking lamps.
Old Nov 4, 2007 | 06:09 PM
rowdy235's Avatar
alright, but as I mentioned above I want the foglights to turn off when I turn the lights all the way off. Would wiring it to the + side of the parking lights allow me to run the foglights when the lights are on, or just the parking lights are on, but would turn off when the parking lights are off?
Old Nov 5, 2007 | 07:56 AM
Jay351's Avatar
It should since the current flow stops when you turn off the parking lamps. Try it out.
Old Nov 5, 2007 | 07:59 AM
infiltrator's Avatar
couldnt you just do a switch for them? wire them to your battery, cut a small hole in the dash, and then mount a switch in there. ive seen some really cool switches.
Old Nov 5, 2007 | 08:31 AM
superjoe83's Avatar
you could hook up the hot wire of the switch to a ignition lead, that way you can never leave them on and you can use them with out having your parking lights on
Old Nov 5, 2007 | 02:59 PM
rowdy235's Avatar
alright I got some good ideas. Thanks a lot everybody for your suggestions.
Old Nov 15, 2007 | 05:19 PM
Mr.Dabadina's Avatar
if you wire to the parking lights your fogs should work fine with the parking lights only and with the headlights on since your parking lights are also on when your headlights are on
Old Nov 18, 2007 | 09:37 PM
ToysRus's Avatar
Just installed a similar (if not the same) kit. I wired them directly to the battery. Yes, you have to turn them off. But, you're free to turn them on/off without the car's OEM lights. Plus, you can run them with the car turned off if you choose. I've had fogs wired to my OEM lights and I hated it. They cut out when the brights were on. And, they only came on when my lights were on. I want the freedom to run my fog lights with my brights. I'll accept the comprimise that I have to avoid stupidity and turn my lights off when I'm done.
PLUS, for anyone thinking about wiring in some fog lights, it's one of the simplest mods to connect one wire to a battery...one to the body (random screw) for a ground...one to the lights...and one to the switch. CAKE.
Old Nov 18, 2007 | 09:51 PM
Jay351's Avatar
Well with his truck, he has to manually turn on his lights, so therefor he has his switch right there. On my truck you can turn the lights on without turning the truck on. But he just mainly doesnt want to forget to turn off the lights.
Old Nov 19, 2007 | 01:23 AM
magicninja's Avatar
I was thinking about mounting a LED to the dash connected to the light switch, so when the lights were on, the LED would turn on. I know sometimes I forget to turn my lights off when it's raining. I put speakers in my door, and took out he buzzers.
Old Jan 9, 2008 | 03:03 PM
rowdy235's Avatar
forgot to update y'all on this matter. I installed the lights. Because it came with the harness, I followed instructions and wired to the battery. Actually, it works well because the switch is lighted. Thanks all for your help and suggestions.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
