General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
factory/dealer fogs for 97 4runner help
Old May 31, 2006 | 08:59 AM
Zona4r's Avatar
Hey all,
first time posting but a long time reader. I had the fuse blow on the factory/dealer installed fog lights (hella) on my 97 4runner. Anyone know how to get in and replace it? Just thought I'd ask around before i went in there myself.
thanks
Carl
great site btw. lots and lots of great info
Old May 31, 2006 | 10:33 AM
Godzilla's Avatar
The fuse should be in the fuse panel under the hood. Look at the fuse map underneath the fuse panel cover to see if there is a fuse in the specified position..i think mine is a 5. Just pop out the old one and put in a new one. If you are blowing fuses check all the wiring as there may be a short somewhere.
Old May 31, 2006 | 11:45 AM
Zona4r's Avatar
This is not a fuse in the normal fuse box, but a remotely located (in-line) fuse. it blew because i switched from the dealer installed lights to the Hella Optilux 2020 combo lights. I have them wired to the original switch (using original wires and in-line fuse) so both come on at once and not separately. I just need to put in a higher amp fuse in to solve the problem (I'm guessing). If this should be a big concern for me please let me know and I'll think of something else.
Basically, i need to how, if possible, do i get into and change the fuse in the Hella in-line fuse box. I can't see how to open it without taking it off. I didn't have time to do this before work this morning.
Thanks
Carl
Old Jun 2, 2006 | 08:11 AM
gpcollen1's Avatar
So are both of them not working now or just the Hellas? I am no expert but... you need to evaluate the wiring prior to just upgrading the fuse.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
