factory/dealer fogs for 97 4runner help
Hey all,
first time posting but a long time reader. I had the fuse blow on the factory/dealer installed fog lights (hella) on my 97 4runner. Anyone know how to get in and replace it? Just thought I'd ask around before i went in there myself. thanks Carl great site btw. lots and lots of great info |
The fuse should be in the fuse panel under the hood. Look at the fuse map underneath the fuse panel cover to see if there is a fuse in the specified position..i think mine is a 5. Just pop out the old one and put in a new one. If you are blowing fuses check all the wiring as there may be a short somewhere.
This is not a fuse in the normal fuse box, but a remotely located (in-line) fuse. it blew because i switched from the dealer installed lights to the Hella Optilux 2020 combo lights. I have them wired to the original switch (using original wires and in-line fuse) so both come on at once and not separately. I just need to put in a higher amp fuse in to solve the problem (I'm guessing). If this should be a big concern for me please let me know and I'll think of something else.
Basically, i need to how, if possible, do i get into and change the fuse in the Hella in-line fuse box. I can't see how to open it without taking it off. I didn't have time to do this before work this morning. Thanks Carl |
So are both of them not working now or just the Hellas? I am no expert but... you need to evaluate the wiring prior to just upgrading the fuse.
