General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Easy aftermarket reverse light set-up questions
Old Apr 25, 2012 | 08:15 AM
TexFF's Avatar
I bought a cheap pair of Optronics 4"x2" lights to use as reverse lights. They claim to be 55w each but I highly doubt that. I want to simply run a hot wire from each light to each factory reverse light wire and ground them individually. Can this be done without diodes or relays? I really don't want to mess w/diodes and relays mostly because I'm really electrical ignorant and I'm lazy! I'm not installing a switch. They will only be operated by putting my rig in reverse. If I do it the way I want, should I remove the factory reverse bulbs so there's less load on the factory wiring/fuse? Thanks.
Old Apr 25, 2012 | 08:34 AM
waskillywabbit's Avatar
Numerous lighting websites with diagrams.
Quit being lazy and search.
:wabbit2:
Old Apr 25, 2012 | 10:25 AM
TexFF's Avatar
:wabbit2:
Thanks but I don't need a diagram. I want to simply run a hot wire from each light to each factory reverse light wire and ground them individually. Can this be done without diodes or relays? If I do it the way I want, should I remove the factory reverse bulbs so there's less load on the factory wiring/fuse? Thanks.
Old Apr 26, 2012 | 03:52 AM
90toy4x4's Avatar
Use a relay and power it from the fuse panel or expect to replace your reverse switch a lot. One relay is all you need. Takes all of 15 minutes.
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
