General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Door Control Assembly
Old Jul 31, 2015 | 08:25 AM
JAMGarcia's Avatar
I am looking for a door control assembly 85980-89101 for my 1st gen 4Runner. I have replaced the passenger switch (working fine now) & recently replaced the master control switch & the passenger switch is still inoperable. I have had my door control soldered where it needed it.
Any help from anyone would be greatly appreciated.
JAMGarcia
Old Jul 31, 2015 | 10:28 AM
wyoming9's Avatar
Red face
Just pray tell what is a door control assembly ??
Old Jul 31, 2015 | 10:33 AM
Terrys87's Avatar
Are you talking about electric window switches on the door?
Old Jul 31, 2015 | 12:30 PM
JAMGarcia's Avatar
It is a module that controls the power windows.
Old Jul 31, 2015 | 12:36 PM
JAMGarcia's Avatar
Yes it is for the power windows. The passenger side switch works & the drivers side master switch side does not work. All other switches work on master control switch.
Old Jul 31, 2015 | 12:52 PM
wyoming9's Avatar
Red face
You do know that when in the right door switch is in neutral position it allows another set of contacts close.
This is what allows the Master switch to control the other windows.
You have checked these contacts are good??
As well as checked for broken wires in the harness??
If your talking about the door control relay if this has failed none of the windows will work>
You say yours does
Now just what year are you working on.??
Old Jul 31, 2015 | 02:06 PM
JAMGarcia's Avatar
The passenger switch was replaced & the driver master switch was also replaced. The wiring on both switched matched the OEM switches. I have had the door control assembly soldered twice.
I have an 86 first gen.
Old Jul 31, 2015 | 11:46 PM
wyoming9's Avatar
Red face
Best of luck maybe you can find one on here or another Toyota forum or Ebay
rusty904
Mar 27, 2017 05:20 PM
mussy01
Dec 13, 2016 08:20 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
TDonkey
Jul 26, 2015 10:14 AM
