General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
corner lights and tail lights gone!!
Old Apr 16, 2007 | 09:25 PM
Travisfab's Avatar
All the sudden my corner lights, tail lights and brake lights went out. Fuses seems to be fine, blinkers still work. Any ideas?
Truck is a 94 22re
Old Apr 16, 2007 | 09:29 PM
Elton's Avatar
its magic lol bad ground ?
Old Apr 17, 2007 | 05:59 AM
Travisfab's Avatar
If it helps the gauge lights and dash lights are out as well. The dome, and stereo do work though.
Old May 9, 2007 | 06:03 PM
weakyota91's Avatar
did u check both fuse blocks. on under hood and the one inside truck.
Old May 21, 2007 | 06:11 AM
HaveBlue's Avatar
My truck is doing the same thing. It's blowing fuses for no apparent reason. I haven't touched the parking lamps at all and now, all of the sudden, fuses are popping left and right. Any advice?
Old May 21, 2007 | 06:19 AM
Chief_Yota's Avatar
,i had the same thing,and it was directly related to my sensor on the transmission ,i think its the backup sensor (not sure thoe)
anyway i played with that last time and when the wire ground itself on the frame it blow fuses,like dash gauge,tailights and even the 4wd wont work cause of that.pretty wierd huh
Old May 21, 2007 | 06:35 AM
HaveBlue's Avatar
Oh, snap! I better check my 4WD then. If that doesn't work, I'm really going to be mad!
EDIT: Just went out and checked - 4WD still works fine (big sigh of relief)
Sep 4, 2015 09:27 AM
skebe22RTE
Jul 31, 2015 02:03 PM
PopsDad1
Jul 30, 2015 02:21 PM
sabine
Jul 18, 2015 03:59 PM
Johntom240
7
Jul 13, 2015 12:18 AM
