General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
clicky starter? 82 yota
Old Aug 4, 2006 | 08:46 PM
cool_racer's Avatar
ive got a 82 yota, pulled out of my uncles junk yard/woods, brought it home threw a battery in it, started on up. just like a yota. any way the head gasket blew and i just got finished putting one on. i had a problem with the starter clicking when starting before the gasket blew but it would only click once or twice, now it does nothing but click. (once it starts to turn it will turn fine) is this a starter issue or a solenoid issue. i dident have any one to turn the key so i dont know exactly where the the click is comming from. also on all the vaccume lines i cut them all out (and plugged the holes) and then realized one advanced the timing. can i just run a tube to the intake to advance the timing and plug off the retarding line?
Old Aug 4, 2006 | 08:48 PM
cool_racer's Avatar
also i have a good charged battery (out of a powerstroke) with clean good connections
Old Aug 5, 2006 | 11:27 AM
4Crawler's Avatar
Have a look at the following page for the answer:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old Aug 20, 2006 | 07:21 PM
Ditchpig's Avatar
You don't have to look at that page. Take your starter off the truck. Use jumper cables and put the (+) on the battery to the pin that the nut screws onto and then hook the(-) side of the battery to the housing. Jumper from the ignition switch wire to the (+) pin and the starter should fire up if it's going to. Sounds to me like you have bad contacts and need to change them out, it's cheap and easy.
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
